588,478 active members*
5,052 visitors online*
Results 1 to 6 of 6
    Nov 2004
    8
    Drip Feed Problem / Greco
    Dear All,
    We have got a 1985 Cincinnati mill with Acramatic 850 , we have
    purchased a BTR from Greco , and WinDNC , for short programs drip
    feeding is great , but for long program the machine stops moving with
    no error on the screen , once we push the start cycle bottom it
    continuous
    as if never stops , this may happen three or four times in a2 hours
    program !! . The stops has no clear pattern and very random ,
    Where is the problem ? Any help?
    Shadi
    Oct 2007
    53
    Please check the shield cable of RS-232 wire. It must be connected to Ground at one side, while other side must be left open in air. It might be due to external noise pick-up
    Nov 2004
    8
    The Cable is quality shielded , is the noise the only possible reason ? , could it be from the WinDnc , Is there an under DOS program instead?
    Thanks ...
    Shadi
    Nov 2004
    8
    The Cable is quality shielded ! Is the noise the only possible reason ? Could it be the WinDNC , is ther an under DOS program I should try ?
    Shadi
    Oct 2007
    53
    Random stops
    Quote Originally Posted by salhab View Post
    Thanks ...
    Shadi
    Dear Salhab,
    1) Since it is random I suspect a noise problem. It works well on short programs means, buffer is OK on Greco. The problem comes on long programs only. Because, Greco sends sends X-off signal which is acknowledged by Win-DNC.
    But, when X-on comes from CNC side, it is not recognized hence machine stops for want of data from PC. X-on & X-off are software hand shake signals.
    2) I do not think, DOS based program will solve this problem.
    3) The cable is quality shield. OK. But one end must be ground & other end must be open in air to have a proper effect.
    4) Try with smaller cable length.
    - Deepak Bodhani
    www.digitech-engineers.com
    Oct 2008
    26
    Has it ever worked in the past?
  1. BMC-20 w/Max II drip feed......
    By GPena in forum HURCO
    Last Post: 10-31-2007, 06:37 PM
  2. Drip Feed - DNC - Fanuc 16i
    By gm3211 in forum DNC Problems and Solutions
    Last Post: 09-21-2007, 08:43 PM
  3. Drip feed Boss9
    By pcsimp in forum Bridgeport / Hardinge Mills
    Last Post: 08-12-2006, 01:38 PM
  4. Drip Feed
    By camtd in forum Surfcam
    Last Post: 08-01-2006, 12:09 AM
