This is the most trusted CNC controller for both novice, and pro. This package makes the G540 fully USB compatible, meaning you can use it with ANY Windows based operating system. You can use either 32bit or 64bit Windows 7 or 8 even laptops.
Included in the package is the UC-100 USB to parallel port converter to make the G540 fully USB. Plug it in the G540, and plug the USB in your pc, and install the driver for simple USB performance. Works perfect with Mach3, or CNC drive's USB motion control software.
This package also comes equipped with a 48v 10a power supply to provide the G540 more than enough amps in even the most demanding 4 axis setups.
$500 Shipping is included in the price. Price only valid if you message me through Ebay. Contact me here direct through my store items in eDealers Direct store on eBay!
If you would like to add 3 300oz in steppers featuring dual shaft (1/4 or 6.35mm shaft diameter) add $120
