![Quote](images/misc/quote_icon.png)
Originally Posted by
TXFred
The reason I wanted smaller on the X is because the X motor sticks out and moves the center of gravity of the saddle. It's my belief that the CG should be on top of the ways.
I can always use a counterweight, but I like the way that you did yours. By slinging the motor down under, you likely kept the center of mass between the ways.
Frederic
That was my feeling exactly, I wanted to keep the mass under the saddle, and I was also wanting to keep the footprint no larger than the original lathe (no motors sticking out anywhere).
<a href="http://www.cnczone.com/forums/mini-lathe/82871-7-x-10-project-started.html" target="_blank">7X10 Lathe conversion</a>
<a href="http://www.cnczone.com/forums/open-source-cnc-machine-designs/335846-cnc.html" target="_blank">Custom X-Carve router</a>
<a href="http://www.linkedin.com/in/tooldesign" target="_blank">LinkedIn</a>
