588,342 active members*
5,421 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > stationary spindle with X,Y,Z movement
    Oct 2003
    15
    Looking for "the" answer. This is to be used on a Haas Mini Mill.
    Objective: to hold spindle stationary, but to use the X,Y and Z axis to cut with auxiliary electric spindle. Want to use post generated by SurfCam to control table movement.
    Tried: M19 "spindle orientation" inplace of Sxxxx M03.
    Movement OK till "Can" cycle line. Then error 186 basically stating spindle not turning.
    Just trying to avoid having to long hand write a program without the can cycle because in hole drilling a peck of 2 tenths for .110 deep is needed, muchless the profiling required.
    I know it's the can cycle stopping me, however I have seen a Fadal and a large Taiwanese mill do this very thing with a auxiliary spindle.
    Any help will be very much appreciated, thanks in advance.
    Apr 2003
    1876
    Couple things to try; M03 S0000 or not using a canned cycle. Do the drilling long-code. (I can't say about surfcam, but I know mastercam can post long drill cycles via a switch in the post or a custom drill cycle)
    HTH
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Oct 2003
    15
    Rekd, good thought "M03 S0" doesn't work as the spindle speed minimun is 10RPMs. Mastercam is not an option I have SurfCam. I will investigate the custom drill cycle option.
  1. Sherline spindle to 30k RPM -- am I crazy?
    By nicad in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2010, 09:57 PM
  2. CNC Controlled Spindle motor speed control
    By gregmary in forum CNC Machine Related Electronics
    Last Post: 02-28-2009, 02:01 AM
  3. Gilman box spindle pics
    By Swede in forum Benchtop Machines
    Last Post: 03-30-2005, 04:41 PM
  4. Stationary spindle motor using ball spline?
    By GalaticDan in forum Uncategorised MetalWorking Machines
    Last Post: 02-12-2005, 01:59 AM
  5. 2.2KW Allen Brad. Spindle motor?
    By GalaticDan in forum Servo Motors / Drives
    Last Post: 02-02-2005, 06:46 PM
