587,999 active members*
2,096 visitors online*
    Dec 2005
    134
    how to adjust for lost motion on M15 controller
    I have about .006" lost motion in my "Y" axis on my knee mill and that is the best I can get it. I have taken everything apart and cleaned and readjusted my gibs and checked everything with an indicator but I can't get it any better than that. How can I use the cnc control to account for the lost motion?
    Feb 2008
    280
    There has to be a mechanical source that can be fixed. 0.006" is really more backlash than you want to try to compensate for in software.
    Have you checked for axial freeplay in the screw, indicating that the thrust bearings are not secure or (less likely) worn out?
    Have you verified that the yoke holding the ballnut is secure?
    Can you feel the backlash when you turn the pulley back and forth by hand with power removed?
    If you really want to try software lash compensation, it is on the Machine Configuration -> Motor Parameters table:
    1) Press F1/Setup
    2) Press F3/Config
    3) Enter the configuration password (default is "137")
    4) Press F2/Machine
    5) Press F2/Motor
    6) Arrow over and down to the Y axis lash comp value
    7) Enter the desired compensation amount
    8) Press F10/Save
    9) Press ESC three times to return to the main screen.
    If you have newer software (since perhaps 2003?) you can also access the lash comp amounts from the Utility screen: F7/Utility, F6/User Maint.
  1. CNC USB motion controller
    By Kroko in forum News Announcements
    Last Post: 01-03-2014, 01:58 PM
  2. 9000 files lost on OM B controller
    By bcbackoader in forum Fanuc
    Last Post: 06-24-2008, 06:21 AM
  3. the Motion group Controller
    By 47MLB in forum Machines running Mach Software
    Last Post: 07-23-2007, 10:16 PM
  4. Australian controller - lost
    By tim99 in forum DIY CNC Router Table Machines
    Last Post: 05-29-2007, 11:13 AM
  5. PARKER 6K2 or 6K4 Motion controller
    By TUCSONCNC in forum Post Processors for MC
    Last Post: 02-02-2007, 07:07 AM
