587,236 active members*
3,502 visitors online*
    Sep 2008
    100
    Mach 3 and Burny 3
    Ive just been offered the box that goes under a burny 3 controller with the servo drive cards in and all the buttons on the front, i presume it has input and ouput cards as well, my question is can mach interface with this using step / direction or does it work on a bus or some needlessly complicated system like that? It would be ideal if i could connect to it since i dont really want the burny 3 but the servo drives would be nice.
    Thanks for any help
    Matt
    24223
    IIRC, the Burny uses analogue drive control.
    Al.
    Albert E.
    Hi Matt,
    Al is right, the Burny3 uses an analog drive signal and encoder feedback to keep track of where it is. It is a 0 -10 vot signal.
    0 is stopped, 10 volts is wide open and the polarity controls the direction the motors rotate.
    Im not sure about Mach 3, but a Step & Direction system will not drive the Burny/Westinghouse/whatever Burny 3 compatable drives.
    Good Luck,
    Alan Bradford
    www.plasmatechnologies.com
  1. BURNY 2.5 PLUS
    By pftucker in forum Waterjet General Topics
    Last Post: 05-31-2010, 09:04 PM
  2. burny 2.8 led display dim
    By porky118 in forum CNC Machine Related Electronics
    Last Post: 02-11-2010, 12:31 AM
  3. Burny 10
    By Independent CNC in forum Uncategorised CAM Discussion
    Last Post: 11-02-2009, 02:24 AM
  4. anyone got burny 2.5 parts???
    By xjdubber in forum Waterjet General Topics
    Last Post: 09-15-2009, 01:11 PM
  5. Burny comunications
    By Jonp in forum DNC Problems and Solutions
    Last Post: 12-31-2006, 04:35 AM
