587,328 active members*
3,527 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Tree VMC 840 with Dynapath Delta control
Results 1 to 6 of 6
    Jul 2010
    492
    We moved from one shop to a new one in march of this year, got her powered up about a month later since our hurco is our top machine. Anyways, ever since the move, whenever the tree gets done with the program, it zero returns on the axises like its supposed to, but on the z axis it causes the machine to shut down.
    Brief history..... its always made a thud sound when going back to home after a program is done on the z axis, like the z axis bushings are worn maybe? ever since the move tho, it shuts down 90% of the time when it thuds on the z. I am wondering if we stretched the counter-weight chain from the move, or maybe the sensor for the zero got bumped? or maybe the bushings are so worn that its time to replace?
    any clues?
    Oct 2006
    60
    Sounds like 2 problems. Counterweight chains are definitely stretched, replace them ASAP. The issue with it shutting off... is it shutting off completely of just e-stop?
    Call me monday 847-487-4353
    Bob @ ZPS
    Jul 2010
    492
    shuts down, like a loose connection. also, when putting a load on the spindle it seems to do that now as well. i tend to believe its a loose connection now, but will still give you a call tomorrow.....
    thanks bob.
    Jul 2010
    492
    I mean shuts down completely, like a loose connection at the main power switch.
    Jul 2010
    492
    i didnt go in to work today bob, had a couple issues to take care of at home. i will be at work tomorrow and call you then.
    Jul 2010
    492
    well, it seemed to be heat related with the shutting off, now that the temps are in the 90's instead of 99, it wont duplicate the problem. but we did adjust the counter weight so we no longer slam at the z zero spot, and have plenty of clearance to reach the 25 inches till z axis alarms.
  1. Dynapath Delta 20 CNC control
    By gary098 in forum Uncategorised MetalWorking Machines
    Last Post: 12-13-2012, 04:05 PM
  2. Shape Delta 50 CNC Punch with Dynapath 20 control
    By Grahamwragg in forum Dynapath
    Last Post: 06-22-2011, 01:43 PM
  3. Deckel FP42nc with Dynapath delta 20 control
    By Nandop in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 05-08-2009, 04:22 PM
  4. Hurco BMC20 With Dynapath Delta Control
    By Steve A. in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-21-2006, 07:22 PM
  5. Dynapath Delta 20 control
    By Steve A. in forum DNC Problems and Solutions
    Last Post: 08-17-2006, 07:56 PM
