588,657 active members*
5,867 visitors online*
    Feb 2005
    Work coordinate in canned cycle line
    Can you use a G54 command in the same line as a canned cycle?
    Example:
    G43Z1.H1M8
    G55 G82 G98 X2.536Y.155 Z-1.3 R-.95 P50 F10.
    G56 G82 G98 X2.536Y.155 Z-1.3 R-.95 P50 F10.
    Will this format work to drill the same hole in 2 work coordinate systems?
    This is on a Fanuc 0M controller.
    I'm at a new position and the existing programs seem to waste a lot of memory and space with extra lines of code
    4826
    You can always go and try it (without tools or work in place). The control will likely alarm if it does not accept it. Otherwise, just call the work coordinate system on a solitary line before each G82.
  1. Help teach G-code for rookie
    By HighOctane in forum G-Code Programing
    Last Post: 03-16-2006, 04:18 PM
  2. Macro Work Coordinate
    By firedog in forum G-Code Programing
    Last Post: 06-17-2005, 06:03 PM
  3. Haas G85 Boring Cycle (canned)
    By DEAN in forum Haas Mills
    Last Post: 12-08-2003, 05:12 PM
  4. Tool tables
    By Nimrod in forum Mastercam
    Last Post: 11-24-2003, 09:31 PM
  5. Post configuring (black art?)
    By John F in forum OneCNC
    Last Post: 07-18-2003, 07:26 PM
