hi all ,, my CNC machine stop transfer data , it shows alarm P/S 078
what to do ? I am new with Fanuc
Are you sure it's alarm 078? An alarm 087 would be an RS232 buffer overflow condition.
The P/S alarms are usually program format alarms I show this in the alarm list
P/S 078 NUMBER NOT FOUND A program number or a sequence number which was specified by address
P in the block which includes an M98, M99, M65 or G66 was not
found. The sequence number specified by a GOTO statement was not
found. An attempt was made to call a program being edited
Al.
Albert E.
yes as you said Dan Fritz it is alarm 087
RS232 buffer overflow condition. ,what to do please ???
It drive me crazy ...
PS087 alarms occur when the PC sends 10 characters after the CNC has told it to pause.
Are you using a laptop with USB to Serial adapter? I've had handshake problems with these in the past. I would recommend a PCMCIA Serial adapter if you have to use a laptop.
You might also try turning off the FIFO buffers in Windows Control Panel - System - Hardware - Device Manager - Ports - Port Settings - Advanced. Move the sliders all the way to the left, then check the "Do not use FIFO buffers." Okay everything then reboot the computer.
..And of course, your DNC s/w should be set for XON/XOFF software handshake.
Al.
Albert E.
What software are you using to communicate with?
Are you using a 3 wire cable with the Handshake jumpered out?
What is the model of control?
Al.
Albert E.
I send in the attachment picture : SDNC comunication software that I use .
Are you using a 3 wire cable with the Handshake jumpered out ?
I dont know what does it mean ? I am new to this , but it was sending without problem ( i mean the cable is good )
never wanted to be different, I just wanted to be me
You have not indicated what Fanuc model this is, the alarm codes can vary, if it was working on the DNC and now you have o87 alarm, it could mean there is a problem with the I/O port.
Al.
Albert E.
Fanuc series O-M
it was working probably , we were doing cavity for blow mold & we did the rough program we did it in two ways buffer and save butthe finish program was too long to save , that is why we tried to do buffer !!
Well here is the P/S alarm right out of the manual.
'087 BUFFER OVERFLOW When entering data in the memory by using Reader / Puncher interface,
though the read terminate command is specified, input is not interrupted
after 10 characters read. I/O unit or P.C.B. is defective.'
It looks like the handshake is not on, if the external PC does not stop or sends more than 10 characters after the DC3 stop code has been sent from the CNC, then 087 alarm will occur.
What transmission baud rate are you using?
Al.
Albert E.
we use this :
bit per second 9600
data bit 7
parity even
stop bit 2
that what I understood from the reply
we use :
pit per second : 9600
Data bit : 7
Parity : even
stop bit : 2
this what I understood from your reply ... sorry I am CAD/CAM engineer
we bought the USED machine ready to receive from Mastercam
You can try 4800 or 2400 baud, you have to change it both ends, make sure the PC software is set for software handshake, if you want the Fanuc RS232 manual, you can send me a email address via P.M.
Al.
Albert E.
I can change it on the PC but I have no idea how to get it on the CNC , i dont know how to do it ? where ?
my DNC software is so simple there is no option or setting to change ..
ya please I need it my E-mail [email protected]
Al_The_ManI appreciate all your Efforts , help and fast reply
and I am thankful for all members for helping ...
Albert E.
السلام عليكم
thank you for your helping ,
but I still want to solve my problem , I need little help , yesterday I send you the my CNC photo , can you tell me in steps how to reach bound rate menu 9600 on the CNC to change it ? in the main screen what to do ?
can I find the guide in the manual ??
Try this software http://www.cadem.com/ it's free...I had problems with sdnc...use this software an you can adjust the 10 characters to help eliminate this alarm.
The two parameters that deal with baud rate are 0552 or 0553 depending on what port you are using, you have to set the PWE bit on the setting screen to 1. to change the parameter, change it back to zero when done.
page 33 shows the baud rate numbers.
Al.
Albert E.
