588,604 active members*
8,282 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Finish Flowline Problem
    Mar 2007
    16
    I'm just starting to do some 3d machining. I'm sure that there's a simple solution for this but the finish on this part is faceted. It happened in all the roughing passes as well. The surface was an iges file made in Rhino.
    Any ideas?
    J
    Nov 2005
    244
    surface tolerance
    While I am new to mastercam. I have seen this with surface tolerances.
    Is there a way in mastercam to change the surface to equal .00002?
    The original model which was probably .002 or more.
    Nov 2005
    174
    You have to tighten up the model toler. Then in mastercam check your filter tolerance as well. I would run about a 2:1 and .0005 or tighter on my finish pass filter. Your model has to be tight also, so check that as well.
    Mar 2007
    16
    Model Tolerances
    Yes,
    It looks like both my model tolerances and my filter tolerances were both off the mark. I'll machine a new test tomorrow and post the results.
    J
  1. Surface finish problem
    By gar in forum Haas Mills
    Last Post: 05-22-2008, 03:01 PM
  2. Finish Cut How too ???
    By Biggermens in forum BobCad-Cam
    Last Post: 05-01-2007, 01:59 AM
  3. 3D Milling Surface Finish Problem
    By TurboME in forum MetalWork Discussion
    Last Post: 12-18-2006, 05:32 AM
  4. Bad finish
    By fadalman in forum Fadal
    Last Post: 12-09-2006, 08:00 PM
  5. flowline plunge
    By smoa1980 in forum Mastercam
    Last Post: 04-23-2006, 06:57 PM
