588,243 active members*
4,240 visitors online*
    Feb 2007
    What is an acceptable endmill tir?
    Hello Guys,
    I'm pretty new to cutter grinding (1.75yrs) and have a ton to questions, but the biggest right now for me is what is considered an acceptable (or standard) amount of tir for an endmill? I guess I'm thinkng somewhere around 0.0005", but just am sure. FYI, I'm running an ANCA RX7 and using Schaublin collets, and find that I have to indicate all my tools to consistently get to that number.
    Rob
    Jan 2007
    5
    Tir
    TIR is a ratio to size and length the machinist hand book has the tolerances,check it out. How ever a like a dead needle if i can only check shank and I also stone around the shank if it is High Speed . Well I never used a CNC i out produce them by 50% and have to many skills. good luck
    Sep 2010
    runout
    with todays chucks and collet quality u should not need to indicate standard size tools we hold a tenth or two all day long unless u have an odd shank size or an x long tool or a lot of grind marks in u chuck oh our max runout allowed is .0005 on new builds and .001 on regrinds
  1. How much spindle runout is acceptable?
    By sbalder in forum MetalWork Discussion
    Last Post: 12-14-2006, 04:11 AM
  2. 220v acceptable range from power co.?
    By jderou in forum CNC Machine Related Electronics
    Last Post: 11-06-2006, 04:58 PM
  3. OUCH: 0.0007% Error rate not acceptable
    By Geof in forum Haas Mills
    Last Post: 07-02-2006, 04:09 AM
  4. Is 0.005-0.010” of backlash with an Acme Screw acceptable?
    By MrRage in forum Uncategorised MetalWorking Machines
    Last Post: 12-21-2005, 03:50 PM
  5. what is a acceptable dc ripple for gecko/rutex
    By sendkeys in forum CNC Machine Related Electronics
    Last Post: 06-25-2004, 10:26 PM
