588,212 active members*
4,322 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > English manuals for Type3 and NCStudio please
Results 1 to 14 of 14
    Nov 2010
    15
    We have just purchased our first CNC router from China. It came with Type3 v 4.3 CAD/CAM and NCstudio v5.5.6 controller software. The manuals they provided are hard to understand. Does anyone have clear English manuals for either software or any tips they would be willing to share with us? Can email to [email protected].
    Any help would be appreciated.
    Jun 2009
    96
    Dear Andus,
    Please show which software you bought with your machine, becasue now many many companies using copy softwares, some different functions.
    we are also Type3 distributor for north China, we will know if it is reall original or copy with the dongle.
    For NcStudio, also please show if it is original or copy one, many kind people will supply help from here.
    roctech
    CNC Router ATC|CNC cutting machines|CNC router machine Manufacturer-RocTech
    Nov 2010
    15
    Hi Roctech
    The software is type3, [4.3.0.0] [2] simplified Chinese version and NcStudioV5.5.60.0
    Jun 2009
    96
    Quote Originally Posted by andus View Post
    Hi Roctech
    Could you show some proof that the software is original or no? such as dogle pictuer and serial number?
    your machine supplier didn't give you the manual?
    ROCTECH
    Nov 2010
    15
    Hi Yes my supplier gave me a copy of the manual but it is hard to understand and the dongle is yellow and it has pro, type edit on it and some numbers with aladdin.com patented
    Jun 2009
    96
    Sorry, we cannot say it is original or no.
    If possible please talk to me by MSN [email protected] or SKYPE: smark.zhang
    Roctech
    Nov 2010
    15
    Thank you for your help roctech
    Jun 2009
    96
    Our pleasure!!!! hope the videos help you!
    Roctech
    Mar 2011
    61
    Talking
    The type3 mnual can be downloaded in english at
    http://cadfamily.com/download.ASP?ID=293439
    wizzardworks
    Mar 2011
    61
    Quote Originally Posted by wizzardworks View Post
    wizzardworks
    manual for the NC studio can be found at
    Http:/www.saleCNC.com/manuals/CNC_ROUTER_MANUALV4.4pdf
    wizzardworks
    Nov 2010
    15
    Thanks for that. Can't open the CADFamily link. The NC studio manual is the same as the one we have and it is not easy to understand.
    Mar 2011
    61
    When a likn doesn't work you can highlight it by holding the left mouse button and dragging across the link. Then click page/copy and wait a minute then click on thesearch bar and click page/paste to get it up there then search. I have this problem with G.mail under internet explorer. You can also search for CADFamily to get to their home page and navigate to the file there. Often there is a choice between .pdf and httm and if one doesn't work try the other.
    I searched for "cad cam software manuals download free " and found all three of them in half an hour. They were from 3 different sources. Ignore any listings including torrent or crack and if you don't find something by the fifth page redefine your search.
    wizzardworks
    Mar 2011
    61
    NCstudio in operation works like your windows print spooler. You open a file and run it with the router thinking it is the printer. There is of course the ability to modify the cutting speed and spindle RPM while the progam is running the file. These things are however set in the G-code file when you created it in other software.
    At the installation stage you don't need a G-code file. After the program is launched you can use the mouse on the directional buttons in manual to see that the limit switches allow the rated travel on the table. At this time remember which is your X and which is Y so you can get your material turned the right direction. Then set the zero point by traveling the spindle with the manual buttons and selecting "set zero point." You will also need to set an incremental travel and run the machine one increment and measure how far it moved. If the calibration or limit switch polarity are off go to youtube and search NCstudio and watch the tutorials (several times)
    The more complicated part is creating the solid model and the G-code file used to cut it out. Cut one of the sample files in type3 (saved as fanuc16M/0M) and get comfortable with operating the router with NCstudio. These files are not created within NCstudio and if you are trying to operate the machine with only NCstudio then only straight manual cuts are available.
    There is a sectiom on CNCzone where people post and share their files which you can load directly without using the file creation software.
    wizzardworks
    Nov 2011
    good day everyone. can someone aid me in finding an english version of ncstudio operating manual?
  1. Ncstudio Upgraded Version V5.5.60 (ENGLISH)
    By EXLASer in forum Commercial CNC Wood Routers
    Last Post: 04-25-2019, 07:15 AM
  2. Type3
    By Hardywood in forum Uncategorised CAM Discussion
    Last Post: 12-28-2012, 02:38 AM
  3. who knows something about type3?
    By vikki007 in forum DIY CNC Router Table Machines
    Last Post: 12-31-2010, 06:09 AM
  4. Need type3 software information
    By rdludlow in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-20-2010, 03:36 AM
  5. Type3 software
    By evertongodoy in forum Uncategorised CAM Discussion
    Last Post: 07-12-2010, 01:42 PM
