Quick Questions
1. I have a Dremel 4000 as my spindle for my 6" x 6" Cutting area desktop machine. The RPM ranges from 5000 to 35000. Just making sure, but should i buy 2 Flute endmills since the rpm is so high? Also, since Dremels only hold up to 1/8" shanks, i'm going to turn down the shanks on 1/4" bits using my 7x10 metal lathe (if it's even possible to cut carbide bits).
2. I have some NEMA 23 Stepper Motors that are rated at 3A, 1.8*/step. They are dual shaft with NO flats. they are cube shaped motors (2" x 2" x 2"), not those long rectangular shaped NEMA23s. Code: FL57STH56-3006B. Does anyone know the oz/inch for this stepper.
Thanks.
(* = Degree)
A machine is only as accurate as the tools used to build it. "CNC = Computer Numeric Control - or on some days - CNC = Can Not Control" Imagineering
