588,548 active members*
5,774 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > New X5+, some quick questions
Results 1 to 6 of 6
    Jul 2011
    Hi all
    I've recently taken delivery of a Syil X5+, running on Mach 3 and using the metric Syil setup file from the Syil US webpage.
    I have a few problems/questions, here we go.
    1, Limit switches, they dont seem to do anything for limiting the axis travel when jogging in both manual and CNC mode. It'll just jog straight past the limit switch. In the Mach diagnostics page I can see the switches lighting up when I press them manually and they seem to do the right thing when I home the machine in mach. Is this just how it is or should the switches limit travel at all times?
    2, I cant get the MPG to work with Mach, I'm guessing its a config thing but I cant find it. Any ideas?
    Other than these issues it seems to be a nice machine, looking forward to getting stuck into some proper jobs with it.
    Regards
    Bedfo
    Apr 2006
    844
    did you use the xlm which for your machines,?
    monday,we will provide a xlm for you,give me your email address.
    MPG not working on the cnc mode,only works at manual mode.
    Direction,Commitment,Follow through
    Jul 2011
    Wow, what a fast response!
    1. Yes I am using the xlm file as recomended by Hugh at Syil UK, it was downloaded from here Syil America - Support
    I have sent you a PM with my email address, looking forward to trying your xlm file.
    2. Ok thank you, I will stop trying to figure that one out now!!
    Thanks!
    Bedfo
    May 2005
    925
    Quote Originally Posted by bedfo View Post
    Config menu>port and pins>input signals tab> enable X++ and x-- with the same parameters as X Home. Do this for Y and Z axis. Now if you push the limit switch after referencing it will trigger an e-stop
    Not designed to be used under mach3 control, I designed an interface to attach the MPG to a second parallel port to be used with mach3, very handy! Check this post or contact me if you want a ready made unit + extra parallel port.
    Pablo
    ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
    Jul 2011
    Hi Syil
    Any progress with the xlm file you mentioned? I have not had anything on the email, did you get the private message I sent?
    Email address is mrbedfo@googlemaildotcom
    Regards
    Bedfo
    Apr 2006
    844
    i have been sent email to you..thank you
  1. Quick Questions
    By AssassinXCV in forum DIY CNC Router Table Machines
    Last Post: 07-07-2011, 08:26 AM
  2. Just some quick questions.
    By elliottjempty in forum Servo Motors / Drives
    Last Post: 05-09-2009, 04:56 PM
  3. 2 Quick questions
    By idtkid in forum Benchtop Machines
    Last Post: 02-22-2009, 02:14 AM
  4. Quick questions for anyone using v21
    By cnczoner in forum BobCad-Cam
    Last Post: 08-29-2007, 02:07 AM
  5. quick questions on a DIY Job
    By faceless105 in forum DIY CNC Router Table Machines
    Last Post: 08-25-2006, 09:52 AM
