588,548 active members*
5,774 visitors online*
Results 1 to 10 of 10
    Feb 2007
    167
    2 Quick questions
    If you have a CNC'd machine and you wish to manually control the axis does turning the screws create a current that is sent back to the drivers/boards?
    Also, if your manually using a CNC'd machine that is run by servos, can you use the encoders to give DRO output?
    Thanks for your help!
    Dec 2008
    445
    Quote Originally Posted by idtkid View Post
    You have to shut the drives off the motors in order to use the machine manually.
    To the second question the short answer is no. The encoders go to the drive not the computer, which will be off if you are using it manually.
    Once again, as many have posted before me. There is no need to "go manual". Once you get comfortable you work pretty fast with no "manual mode" using things like MDI and jog. You also gain the benefit of power feed like this. There really is no reason to take great pains to "go manual" as it gives almost no gain. You may be more comfortable now with a manual machine, but it will quickly wear off.
    A small amount for as fast as you would crank by hand.
    [ame="http://www.youtube.com/watch?v=B9emjJxXZ0c"]http://www.youtube.com/watch?v=B9emjJxXZ0c[/ame]
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Mar 2008
    3655
    That was very well answered. I will only add:
    If your CNC machine has ball screws, then only locked up motor holds the axis. Without the motors powered, there is no friction to hold the axes against cutting force. Unless you locked all axes but the one you were moving, accurate manual milling would be impossible.
    CR.
    Feb 2007
    167
    Fair enough If you can clarify though, by shutting off do you simply mean turn off the power supply to the motors or would you need an inline switch between the motors and the drives to to stop the current from flowing back?
    Mar 2008
    3655
    Adding a switch between motors and drives is a sure way to see the magic smoke come out of the drive. You can never get the smoke back INTO the drive and it will not work thereafter.
    CR.
    Feb 2007
    167
    And if I could reply to Crevice Reamer specifically, our Bridgeport EZ-track at school was a ballscrew machine (still is) and is both manual and now CNC, wouldnt just the pitch of the screw determine if it could be easilly moved with out turning by hand or not?
    Mar 2008
    3655
    I have never CNCd a Bridgeport, but I'm sure that huge table has a lot more inertia than most benchtop machines. Perhaps all that weight makes manual control more plausable. Is that what you are converting? A Bridgeport?
    CR.
    Mar 2008
    3655
    Or, come to think of it, are there BRAKES on the bridgeport axes?
    CR.
    Feb 2007
    167
    Not converting a bridgeport, was just using that as an example. It has stops you can apply by hand (locking of a nut on the table) but thats it.
    Back to the previous question about current sent back to the electronics, id assume cutting power to the power supply first, then using a switch to break to circuit from the motor back to electronics would be fine? If the motors create such a small current would a simple diode protect the components?
  1. Quick questions for anyone using v21
    By cnczoner in forum BobCad-Cam
    Last Post: 08-29-2007, 02:07 AM
  2. Quick questions on new machine
    By 1ctoolfool in forum Haas Mills
    Last Post: 09-09-2006, 01:59 AM
  3. quick couple of questions
    By faceless105 in forum MetalWork Discussion
    Last Post: 08-28-2006, 04:12 AM
  4. quick questions on a DIY Job
    By faceless105 in forum DIY CNC Router Table Machines
    Last Post: 08-25-2006, 09:52 AM
  5. Two Quick (And yet again very noobie) Questions
    By diarmaid in forum MetalWork Discussion
    Last Post: 06-13-2006, 01:15 PM
