587,287 active members*
4,706 visitors online*
    Mar 2010
    5
    clausing colchester lathe help
    I bought a clausing colchester lathe that has a 220-250v/ 380-440v 50 hertz 7.5hp motor on it. Can anyone tell me if I can run the motor on 60 hertz without burning it up?
    Feb 2009
    6028
    Every machine I see that is 50 hz runs fine on 60 hz. We run colchesters on 60 hz at work no problem.
    24223
    There is less of an issue going from 50 to 60hz than the reverse.
    Al.
    Albert E.
  1. Clausing Colchester Apron Problem
    By paul gibson in forum Uncategorised MetalWorking Machines
    Last Post: 08-15-2011, 01:02 AM
  2. Clausing Colchester problems????
    By banctecbobn in forum Uncategorised MetalWorking Machines
    Last Post: 11-05-2010, 02:00 AM
  3. Gunsmithing lathe - Clausing Colchester
    By DPG in forum Want To Buy...Need help!
    Last Post: 12-01-2009, 05:44 AM
  4. 13X40 Clausing-Colchester 8000 Lathe CNC Conversion
    By mecheng10 in forum Vertical Mill, Lathe Project Log
    Last Post: 10-20-2009, 08:01 PM
  5. Clausing Colchester Repair/ high speed thread attachment
    By naytep in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 09-23-2009, 01:02 PM
