Hello all,
I have a 1995 3 axis eztrack that i'm currently replacing the corroded CMOS battery(moving it to a remote location)as well as replacing the jog knob assembly on it's pendant. Im not sure if the chrome ring on the knob just unscrews or what? any help with that would be great. The more immediate problem I have is with my 2000 3 axis ez trak. This is the so called GOLD BOX unit. It lived as a showroom display/demo model never milling a thing for 7+ years. I purchased this unit about 13 months ago took delivery of it,hooked it up to my phase converter and away we went. I've been using it 4-5 days a week since and havent had any problems with it, until the other day. During a light millng process using the jog feed in (Z) the feed stopped and the crt displayed a -1155750 across the Y axis readout. I checked the limit sensors and a few wires as well as the motor drive wires and didn't find anything so I shut it down. Since then I've started it up several times, with the machine running the X drive homing process than Y. Once it gets to the Y limit at 12.0000 it's as if it trips something the display goes to 30.0000 In X and that same -1155750 in Y never getting to the Z axis. The machine is now locked. I've checked all the parameter settings, checked connections on the BMDC board and M/B including remove the BMDC board and cleaning the connectors.I read an almost identical problem wth one other site member from the UK the solution ther was a loose BMDC board. Maybe I need to get a little more aggresive with the contact cleaning. We have had a bit of condensation get on the machines in the last few weeks. Unavoidable i'm afriad due to the fact that I operate out of my large 2 car garage. Anyway I hope that someone in the collective genius of this site may help diagnose my ills...Thank u all.
