What CNC machine would you recommend for use with your software, for making coin dies?
Hi there,
About what is your budget? Will it be a production or hobby machine?
...they'll need a little more information to make a suggestion
Best,
Jason
My budget is small, I need to have 16 coin dies made, I would like to design the dies myself, and send the G-Code files to be made by someone with the correct machine, of course I would need the the accuracy of the machine first to setup my grid in the software.
Greetings,
VS3D outputs generic G-Code, and there are numerous settings to control the output. So VS3D will work with most engraving/milling machines. I can also make a new version of VS3D to work with other machines, if necessary.
Personally, I use a machine from S&W Engineering. The issue with their machines is availability. It can take a long time to get one.
Daniel Carr - President,
Designs Computed, LLC
