588,656 active members*
5,856 visitors online*
    Choosing correct nozzle and amperage
    I'm wondering the best way to choose what nozzle and amperage to use when cutting steel. I run a powermax 125, the book says I can cut 3/8 plate with a 65a nozzle or a 125a nozzle. Which would be better and why?
    Jan 2008
    2247
    Re: Choosing correct nozzle and amperage
    The best cut quality with any plasma cutter is when you use the lowest amperage consumables that the listed cut charts say will cut the material. The 65 amp process will produce a squarer edge, better definition on holes and fine features because it operates at slower speeds. If you are looking for best productivity, then use the 125 amp process....very fast, but not quite as accurate and a little more edge taper.
    Jim Colt Hypertherm
    Quote Originally Posted by cory1504 View Post
  1. Help choosing the correct operation
    By cobrakai in forum SprutCAM
    Last Post: 01-12-2014, 08:12 AM
  2. choosing the correct epoxy resin
    By jerrywi in forum Momus Design CNC plans
    Last Post: 04-07-2012, 02:23 PM
  3. T80M Nozzle and Amperage Selection
    By Stout in forum Hypertherm Plasma
    Last Post: 10-02-2011, 07:55 PM
  4. amperage rating
    By miljnor in forum Servo Motors / Drives
    Last Post: 08-30-2005, 09:53 PM
