588,496 active members*
4,539 visitors online*
Results 1 to 6 of 6
    Mar 2004
    152
    Corrosion Removal
    Anyone with ideas or know the best chemicals to remove corrosion and rust from an older CNC lathe Turret.
    Lots of corrosion and rust where the coolant has been.(heres a photo) Attachment 505326
    Any help or suggestions would be great
    Apr 2004
    5760
    Re: Corrosion Removal
    You can use washing soda and a battery charger to remove rust on anything you can submerge in a tank. https://www.garagejournal.com/forum/...emoval.154196/
    Andrew Werby
    Website
    Nov 2013
    4614
    a moderately strong solution (5%-10%) of phosphoric acid. Paint it on, leave for an hour or so to dissolve the rust, and then thoroughly rinse it off.
    This is the basis of quite a few of the 'Etching Primer' solutions. Old school but it works.
    Craig
    Mar 2004
    152
    Great , thanks Guys
    will give it a go:banana:
    Jul 2018
    6532
    Hi Jubee - double strength vinegar works a treat (normal vinegar to just takes longer) and is friendly on the skin... If you can put it in something and soak it the rust will be gone overnight. A nylon bristle brush will remove the plaque easily after a soak. Peter
    Mar 2004
    152
    much appreciated.
    I still have a few things to do, so will try that as well. Thanks Peter
    here is a before and after photo with phosphoric acid i bought from Bunnings. It really turned the rust black and bubbled up into Black goo.
    I cleaned it up and looks good now.
    Attachment 505768
    Attachment 505770
  1. Vise corrosion protection
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 08-16-2016, 07:39 PM
  2. Tool Corrosion
    By Jabs1542 in forum Tormach Personal CNC Mill
    Last Post: 06-13-2014, 02:56 AM
  3. 7075 Corrosion
    By inmoteng in forum MetalWork Discussion
    Last Post: 08-01-2012, 07:57 AM
  4. coolant corrosion issues
    By Gnome in forum MetalWork Discussion
    Last Post: 04-26-2010, 07:33 PM
  5. Corrosion Preventive treatment
    By BigDog66 in forum Tormach Personal CNC Mill
    Last Post: 01-01-2010, 10:13 PM
