During a momentary lack of attention, I restarted a program not realizing that my Fanuc 0M-C was still in G84 tapping mode. The Z axis spindle did a rapid travel into a pine 4 X 4. The tap went through the drilled hole until the floating toolholder struck the top of the wood, and the Z axis stalled out. I'm lucky it wasn't a hunk of steel. After I cleared the alarm and positioned Z axis home (home/zero return indication light is on), I attempted a tool change. After many attempts, a tool change is not possible. The Z axis wants to continue to travel in a positive (up) direction. When the alarm appears and the machine movement stops, Z has traveled +.095". "NOT READY" flashes at the bottom of the display, the ready light goes off, but there are no alarms. There is an "OPERATOR MESSAGE NO. 2019". What does this mean? I can use the bypass and ready buttons with the hand wheel to release and clear this condition, but it happens every time I command M06. I tried to hold the [QP] and [CAN] buttons during NC start up, but no luck. I can sure use some help.
