588,202 active members*
4,535 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Cutting Case Hardened Linear Rails
    I have read many questions from the CNCzone members regarding the cutting of Hardened and Case-Hardened steel rails, so here is a little post on how I do it!
    First off, I have a 6x12 Surface Grinder in my shop. A necessity if I do say so! They have a magnetic chuck, which allows for easy holding of steel parts and tools. For this job I used my old grinding vise, which I have rigged up a stop that's nothing more than a piece of pipe with a 1/4-20 threaded rod inside. This holds a little metal plate at a solid point, so all the rails will get cut the same length!
    The grinder has an abrasive cut-off wheel, which is around 3/32" thick. The grinder's RPM is around 3000+ and this will eat the steel really fast! For the sake of taking a movie, I have removed the safety guard from the grinder's spindle. Because the sparks and debris fly all over, I have safety goggles & a dust mask on!
    After all the parts were cut, I took them out of a bucket of coolant which was used to cool them off, and loaded them into my lathe where I face off the burn squaring up the end and bringing it to my desired length.
    Now, I know that the average bloke doesn't have a Surface Grinder, but an abrasive cut-off saw's are really inexpensive and come in a variety of sized. One person even mentioned that the local ACE Hardware store had one which they used to cut pipe!
    VIDEO (15.2 MB)
    Attached Thumbnails Attached Thumbnails 100_2783.jpg   100_2784.JPG   100_2785.JPG   100_2786.JPG
    Apr 2005
    3634
    We have a linear dept. at work that supplies rails for cnc machines, most are about 10-15ft. long, we have a very large C/O saw to rough out the length, then turn/thread/chamfer to finish on the cnc. So it sounds like your doing what we do.
    Are you also turning the threads?
    I think the biggest thing for diy guys at home is they don't have a lathe.
    Free DXF - vectorink.com
    Hey Switch!
    Most of the rails I make are used out of the box, a few get blind holes drilled & tapped, and some get cut to length. All are 1/2" & 3/8" dia.
    Cutting long pieces in my grinder is a bit of a problem, as it only has a throat depth of 10" or so. That requires I cut on an angle, and then cut again to make it square. It's OK for a hobby shop!
    I agree most DIY people don't have lathes, I'd be lost without mine even if it is a Birmingham!
    Widgit
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
  1. 1" Hardened linear rail
    By 2fst4u in forum Waterjet General Topics
    Last Post: 11-06-2007, 07:23 AM
  2. Parting case-hardened rods, what utensils to use?
    By Deusrexmachina in forum Material Machining Solutions
    Last Post: 10-25-2007, 04:29 AM
  3. Spot drilling case hardened steel
    By Zumba in forum MetalWork Discussion
    Last Post: 03-04-2007, 08:32 PM
  4. 20MM Case Hardened or Bright Steel
    By simso in forum Linear and Rotary Motion
    Last Post: 12-28-2006, 12:38 PM
  5. Cutting linear rails
    By Cutloose in forum DIY CNC Router Table Machines
    Last Post: 10-29-2005, 12:42 AM
