588,397 active members*
5,109 visitors online*
    24220
    Handy Little (Electronic) items
    One of the most usefull little few-cent devices I keep on hand is the 2N7000. This is a FETlington, a small fet that replaces small bipolar Darlington transistors, The advantage is that the input is 5v logic compatible (max40v) and of course, high impedance of a FET and will handle 200ma max. drain current and operate devices (relays etc) up to 60v rating. I know there are chips that will do a similar job, but if you only need that one or two relays etc. it is quick and cheap.
    Al
    Sep 2003
    226
    Any particular manufacturer to buy from or avoid with these 2N7000s? Mouser has quite a selection and a cursory reading of the different data sheets reveals nothing that is that different as far as I can tell...Fairchild's are 9¢ each while Supertex's are 27¢, does higher price necessarily give higher quality here? Obviously it is not a money issue at these prices; I just want the things to work dependably.
    http://www.mouser.com/index.cfm?&han...0&N=0&crc=true
    Scroll down a bit for the listings.
    Thanks for any info.
    24220
    I have been using fairchild for about 12 yrs now on a regular basis and do not recall a failure.
    Al
    Albert E.
    Sep 2003
    226
    Wow, That was a quick response!
    Fairchild it is then.
    Thanks!!
  1. Electronic Viscosity damps
    By bunalmis in forum CNC Machine Related Electronics
    Last Post: 09-29-2010, 10:49 AM
  2. Need alist of all the electronic parts
    By Cnc Wana bee in forum CNC Machine Related Electronics
    Last Post: 03-17-2005, 08:05 PM
  3. Need alist of all the electronic parts
    By Cnc Wana bee in forum DIY CNC Router Table Machines
    Last Post: 03-17-2005, 01:36 PM
  4. Cutting "out" items from a sheet
    By MrBean in forum DIY CNC Router Table Machines
    Last Post: 01-04-2005, 06:55 AM
  5. Electronic circuit copyright.
    By ynneb in forum CNC Machine Related Electronics
    Last Post: 06-17-2004, 04:56 PM
