588,572 active members*
11,107 visitors online*
Page 1 of 2 12
Results 1 to 20 of 25
    Jul 2005
    261
    Clear rubber question?
    For a newbie to rubber product making, I'm looking for advice - please.
    I'm looking for a clear-rubber substance; that I can pour into my cast - and will transfer red light from an embedded LED.
    I will make a cast using plastic or aluminum - on my cnc-machine, POUR the rubber fluid into the cast (or mold), and put the LED at the top; set to dry (or cool).
    Either by way of heating rubber in a vat, and pouring in my cast w/ a latel, or mixing a/b solution, or squirting through a tube - I dont know what process would be the best for my application, I could use some newbie advice. I can not have any bubbles in the end-product.
    The consistancy would be something like soft rubber on remote-control keypads, sturdy, and as close to transpararent as possible - I want it to light up when the LED is activated (in the final product).
    Please help!
    WWW.RAIDGEAR.NET - FFC cables, foam headset replacement parts, and other gadgets.
    May 2005
    1810
    Look into water clear urethanes.
    To rid your part of bubbles, you will want a very low viscosity resin and a good mold design.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Mar 2004
    847
    What about silicones?
    Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
    Jul 2005
    261
    I was going to go to the hardware store and buy some tubes of clear silicone / caulk; but have no exp with this and am looking for some research to reduce trial and error time.
    I've been told to try silicones from some rubber suppliers I've contacted (that seem to only want to sell rubber that stands up to super high temp, or radiation or other extreme circumstance).
    I know I can make a mold, and squirt hot-glue from a gun into it and use that - but it melts so easily is not workable (it will melt in a car during afternoon lunch!). A hot-glue gun w/ rods that activate HIGHER would be a nice thing; or something I can mix and squirt out of a caulk gun; it doesnt have to cure instantly I'm patient it can cure overnight.
    Mar 2004
    847
    Well, just so we all are clear. Do you want the end-result to be hard or soft/rubbery? Silicone will stay pretty soft. The stuff in the tubes would be good to test with, I would think...
    Sep 2003
    24
    Depending on how thick your part is going to be, the problem with silicones from the hardware store is the thicker you get the cloudier it will get. It would not hurt to try this method because the expense to try is so low. If this does not work try these websites for some help.
    http://www.smooth-on.com/default.htm
    http://www.freemansupply.com/index.htm
    The smooth on tech reps are very knowledgable & can probably steer you in the right direction. They are also very good fo get small quantities for the hobbiest or DIY'er
    SteveD.
    Jul 2005
    261
    Smooth-on will sell me a gallon of their transparent castable rubber at the generously low price of $200....
    Going to check freeman supply now, and would like to entertain any other suggestions for suppliers please.
    Nov 2005
    83
    Encapsulating and Potting Epoxy for circuit boards might also work.
    It has a rubbery feel when cured. It takes 24 hours to fully cure.
    It's about $20 for a 12oz bottle or $120 for 8gal.
    Allied linky
    Jul 2005
    261
    Is that potting epoxy good for casting something the size of a mustard-cap, for perminant use?
    May 2004
    290
    SmoothOn's main competitor:
    http://www.polytek.com/
    Jul 2005
    261
    I was looking for that - i knew there were two BIG makers for castible products, and didnt know the other one. Thank you!
    Nov 2005
    83
    Quote Originally Posted by DrStein99
    It should be plenty strong enough, but I don't know how much it will contract when cured. The circuit boards I work with are encapsulated in it to a thickness of about 3/8" of an inch. I have tried to remove it from boards before and had to resort to a hammer and chisel. It’s impossible to remove without destroying the board. It's very tough stuff. It's not perfectly clear, it has a very slight amber tinge to it. I would describe the texture and hardness as close to that of wire insulation. Much harder that cured silicone.
    Jul 2005
    261
    I need totally clear / transparent rubber. I am embedding LEDs that are colored; which is the reason WHY it must be transparent-clear (or at most; foggy - white).
    The more transparent clear I can get it; then the more options I have to using my own dyes, colorants, and additives to alter it's appearance.
    Jun 2003
    2103
    Results 1 - 10 of about 667,000 for clear silicone casting rubber
    DrStein99 I promise you I am not trying to be smart acting here but the above is what showed up with a google search for "clear silicone castable rubber". I have looked at tons of these sites and there are many to choose from. You can also get the castable rubber from some larger hobby stores in small quantities..
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    Jul 2005
    261
    I'm looking for advice from people here on this forum. I'm aware of all the sites, i've read alot! The material I read; and the REAL LIFE experience advice people give on forums are two different forms of information.
    Aug 2004
    2849
    ...what are you making....sounds like lighted dildos.....??
    Feb 2004
    2337
    I would also suggest silcon. It is a very inert substance that can resist high and low temperatures, resists chemical contaminants, but has low wearing durabilty.
    Whatever you use the best method to get rid of air bubbles is to put your wet mixture in a vacuum chamber. This causes the little bubbles to expand and float to the surface more easily. In addition to this method, after the vacuum process, you then pressurize the the casting so that if there are any pinprick sized bubbles left ( There shouldnt be) these bubbles will be squeezed into almost nothing. Using this method with a low viscosity material will render a perfect result. You can also use a vibration table to move any bubbles that might be caught under your LEDs.
    Viper, you are a sick and twisted man
    Jun 2003
    2103
    Just trying to help.
    Mike
    May 2005
    150
    here is a site that shows some things made from water clear urithane.
    http://www.ebeffects.com/gallery.asp?p=4
    and here is a site about resin casting
    http://users.lmi.net/~drewid/resin_faq.html
    Aug 2004
    2849
    ynneb....*smile*.....well there was the mention of 'rubber', flashing LEDs, transparency....just key words for my mental database....no mention of 'light pipes' or I would have thought 'industrial application'...
Page 1 of 2 12
