588,619 active members*
4,334 visitors online*
    Jun 2008
    ..the teeth on a pinnion spur gear...
    I'm struggling to draw the teeth on a pinnion spur gear. I used this webpage as tutorial, but ran into problems at step 10. The webpage says the following, but leaves out the "chart" on which to look up the (R) and (r) values.
    Now, to draw the sides of the tooth:
    10. Using a chart (either given to you or in a text) find the (R) radius for the addendum curve and the (r) radius for the dedendum curve of the gear tooth. In this example, the R for a gear having 30 teeth = 4.06 and the r for the same gear = 2.76.
    To get the radii to be used:
    R ÷ DP = 4.06 ÷ 5 = .812
    r ÷ DP = 2.76 ÷ 5 = .552
    Does anyone here maybe have a chart such as this in which there's values to apply to the diametral pitch in order to calculate the radii of the tooth sides in the addendum and dedendum of the gear? Another method to achieve the same results are also welcome, if you can't help me with this chart or if you think the method on the webpage is flawed. How would an engineer draw a gear?
    Also, is the method for calculating the tooth shape of an internal gear the same as that of a "normal" gear?
    Jul 2003
    1220
    This method appears to be a approximate profile as the curve should be a involute.
    Not sure how the R and r are calculated.
    Check this web site for details.
    http://www.qtcgears.com/RFQ/
    See 3. Details of Involute Gearing
    Here is a macro:
    MACRO to GENERATE INVOLUTE PATH with SOLIDWORKS
    Sub main()
    Set swApp = Application.SldWorks
    Set Part = swApp.ActiveDoc
    R = 71.6034 'ENTER BASE CIRCLE RADIUS
    pi = 4 * Atn(1)
    For Ang = 0 To 45 Step 2
    X1 = Cos(Ang / 180 * pi) * R
    Y1 = Sin(Ang / 180 * pi) * R
    Opp = R * 2 * pi
    Opp = Opp * (Ang / 360)
    Hyp = Sqr(R ^ 2 + Opp ^ 2)
    Ang2 = Atn(Opp / R)
    Ang2 = Ang2 / pi * 180
    Ang3 = Ang - Ang2
    X2 = Hyp * Cos(Ang3 / 180 * pi)
    X2 = Int(X2 * 10000 + 0.5) / 10000
    Y2 = Hyp * Sin(Ang3 / 180 * pi)
    Y2 = Int(Y2 * 10000 + 0.5) / 10000
    XX = X2 / 1000
    YY = Y2 / 1000
    Part.CreateLine2 X, Y, 0, XX, YY, 0
    X = XX
    Y = YY
    Next Ang
    End Sub
    Mar 2004
    150
    You can plot the points of a true involute from the base circle by the method of conventional drafting described in the machineries handbook.
    Then calculate a standard circular thickness (this is ARC length) and convert it to an angle based on the pitch diameter. Mirror the involute around the mid point of the angle created, and throw a radius in the bottom (also a calculation) and whalla.
    Keep in mind the radius at the bottom will not be quite like the one a hobbing machine would form.
    Sep 2006
    36
    Post Drawing gear teeth.
    Quote Originally Posted by malJohann View Post
    Hello, It's one of several aproximations, using a circular arc to represent the involute curve. Do not use that one myself, I take points on the involute, calculated with a simple spread sheet taking into account tooth thining (backlash), a three point curve using actual points from the involute can be used to make gears of fair but lower quality, five points, creating two curves will give a form with a couple of ten thousandths. A good general root fillet will be .3/Diametral Pitch. The Internal gear is done the same way. As has been stated, draw one side, mirror, add fillet, radial copy or whatever.
    Cheers,
    Les H.
    Sep 2006
    36
    30 TOOTH 5DP 20 PA GEAR
    So, calcutate points. arc. mirror, copy rotate.
    Cheers Les H.
  1. Simple spur gear design
    By kentavv in forum MetalWork Discussion
    Last Post: 07-10-2014, 02:51 PM
  2. Basic Bevel Gear - Milling a valley for gear teeth
    By ngr1 in forum Uncategorised CAM Discussion
    Last Post: 04-05-2012, 03:55 PM
  3. Diameter, Pitch, Number of Teeth, etc. on Spur gear?
    By SlimJimmy in forum Waterjet General Topics
    Last Post: 12-04-2008, 05:10 AM
  4. Spur gear availability?
    By 2fst4u in forum Waterjet General Topics
    Last Post: 04-02-2007, 02:46 PM
  5. Spur Gear / Gear Rack
    By ckrantz in forum Linear and Rotary Motion
    Last Post: 12-07-2006, 06:06 AM
