588,390 active members*
5,649 visitors online*
    Feb 2006
    42
    Bar feeder question
    Has anyone tried using the bar feeder with sqaure bar stock? Just curious how well this would work.
    Oct 2003
    352
    Edge,
    I didn't forget about you. I just got very busy all of a sudden. I am not sure about the square stock and a barfeeder. Orientation of the stock and collet will be extremely critical. I am sure there is a way but not sure. You said the stock was 22mm? My thought on it (using a Mori, of course), use round stock and mill it square. Barfeeder problems will become 0! We make parts that are square and hexed also. We are about to stop using shaped material altogether. The Mori software makes shapes easily and the round stock is so much easier to hold. What specifics would you like to know regarding the Mori?
    Feb 2006
    42
    I was thinking that about the bar stock also. Do you think if you rounded the edges of the bar it would align when you feed it through? If you want just PM me the price for the mori and what options you have. That would be awesome. Thanks for all you help!
    Oct 2003
    352
    I will put something together Monday morning. The quote for the machine is on my work station. The machine comes loaded to the gills. The only thing that i have been told to do in order to run unattended is add a 1000 psi coolant pump. As far as the square stock, Trusty Cook makes some pretty cool spindle liners with shapes and custom designs. The biggest deal would be to find a barfeeder that would align the bar properly in the liner. Then again round stock is so much easier to use.
  1. Servo 300 Bar Feeder
    By wudbutcher in forum Haas Lathes
    Last Post: 08-24-2010, 04:17 PM
  2. Auto bar feeder
    By DragnsBane in forum Uncategorised MetalWorking Machines
    Last Post: 02-20-2008, 10:09 PM
  3. MTA 541 Bar feeder
    By DocHod in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-03-2007, 04:03 AM
  4. auto feeder
    By Syphonics in forum Mechanical Calculations/Engineering Design
    Last Post: 12-20-2006, 04:14 PM
