Hi guys,
I just bought old machine DAEWOO PRO G with Fanuc System 6T control. The operator panel still using 7 segment and LED Display to select any command.
First time I power up this machine, everything seems to be fine. I check every button, make a reference point and works great. But when I try to rotate my spindle (manual or MDI) the problem show up.
I rotate spindle manually then rotate potentiometer to increase speed of spindle, still Ok ( it shows almost 1000rpm on RPM gauge). But when I try to stop the spindle (rotate potentiometer ccw or push stop button) the machine looks like goes to emergency stop condition. I look into spindle drive and look the LED alarm lit (OVER FIELD).
Anyone here can help to solve my problem? (Especially Dan Fritz... )
Thanks for all your kind attention
Regards,
Andre
