587,657 active members*
8,996 visitors online*
IndustryArena Forum > CAM Software > Mastercam > mastercam info needed
Results 1 to 14 of 14
    Mar 2004
    42
    hallo
    is it possible to run a selfmade pvc milling machine with mastercam?
    I have used the HP-stepper boards from
    www.nc-step.com
    Apr 2003
    1876
    As long as your controller can read the output from Mastercam, it'll work fine.
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Mar 2004
    42
    hallo
    now my controller is connected to the pc with a sub D parallel cabel.
    The controller works with the step and dir controls.
    Is that possible to run with mastercam.
    Now i run the mill with PCNC.
    Apr 2003
    1876
    Does your controller read g-codes?
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Mar 2004
    42
    yes
    my controller reads g code.
    I means that i have to import a hpgl file now in PCNC.
    PCNC translate the hpgl to g code and sent the data to the controller.
    Apr 2003
    1876
    Find or modify one of the posts from MC that's close to what you need and you should be all set.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Apr 2004
    16
    I run Mastercam v7.1 with Mach 2 controller on my new desktop CNC mill.
    I can e-mail the post processor I use, for you to try it out.
    Mar 2004
    42
    yes
    if possible mail me the postprosessor.
    Thene i can tryout.
    thanks
    Jul 2003
    96
    understanding the post processors!
    I run version 8.1 of Mastercam at work and have at times made modifications to some of the port processors we use there for various reasons. I find that I treasure hunt thru it, make a change , and then try it to see if I got it right. I'm wondering where I can get some information, a manual or something so I could get a better handle on understanding the posts to alter them for desired results. ANy help much appreciated!!
    Apr 2003
    1876
    Re: understanding the post processors!
    There's a (rather old) book you can get called Post Processor User Guide- September 1997, that is layed out fairly well. Another option is to get the Post CD from your dealer.
    The best advice I can give you for now is to a) back up your post, and b) turn on debugging.
    Code:
    # Debugging and Factory Set Program Switches
    fastmode    : no   #Posting speed optimizition
    bug1        : 2     #0=No display, 1=Generic list box, 2=Editor
    bug2        : 30     #Append postline labels, non-zero is column position?
    bug3        : 0     #Append whatline no. to each NC line? 0
    bug4        : 0     #Append NCI line no. to each NC line? 0
    whatno      : yes   #Do not perform whatline branches? (leave as yes)
    Then post your file and you'll see where in the post each line came from. This will help you figure out where you need to make changes.
    Code:
    %                             pheader
    O0001                         pheader
    (HOUSING.NCF)                 pheader
    (JUL 05, 2004 10:10)          pheader
    (MC9 FILE: -G_HOUSING)        pheader
    (MACHINE: 3 AXIS)             pheader
    (MATERIAL: ALUMINUM INCH - 6061)  pheader
    (STOCK SIZE: X 4.45 Y 3.5 Z 1.)  pheader
    (TOOL 1: DIA 0.5000  .500 HSS EM 2FL)  pwrtt
    (OVERALL MAX Z1.)             psof
    (OVERALL MIN Z-.72)           psof
    N1 G00 G17 G40 G49 G80 G90 G20  psof
    N2 M01                        psof ptlchg_com
    ( OPERATION: 1   CONTOUR )    psof popnumber
    N3 ( TOP OP 1 )               psof pcomment
    N4 T1 M06(T1: .500 HSS EM 2FL)  psof ptoolcomm
    (MAX-DEPTH | Z-.72)           psof ptlchg_com
    ( TOOLPATH - CONTOUR)         psof p__1:908
    ( STOCK LEFT ON X & Y = -.35)  psof p__1:908
    ( STOCK LEFT ON Z = 0.)       psof p__1:908
    N5 M03 S7500                  psof ptlchg_com
    N6 G00 G90 G54 X-4.8 Y-2.175  psof ptlchg_com
    N7 G43 H1 Z1. M08             psof ptlchg_com
    N8 Z.11                       pzrapid prapidout
    N9 G01 Z0. F50.               plin plinout
    N10 G41 D1 X-4.75 F65.        plin plinout
    N11 G03 X-4.25 Y-1.675 I0. J.5  pcir pcirout1
    N12 G01 Y-.1                  plin plinout
    N13 X-.1                      plin plinout
    N14 Y-3.25                    plin plinout
    N15 X-4.25                    plin plinout
    N16 Y-1.675                   plin plinout
    N17 G03 X-4.75 Y-1.175 I-.5 J0.  pcir pcirout1
    N18 G01 G40 X-4.8             plin plinout
    N19 G00 Z1.                   pzrapid prapidout
    HTH
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Jul 2003
    96
    Thanks for the advice! The turning on the debugging looks like a good start and way to go. But forgive my ignorance, but I don't know how to turn it on for those results. Could you please explain it in a little more detail to get me there? Thanks!
    Apr 2003
    1876
    See where the bold type is? Set yours to match them and debuggin is on.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Jul 2003
    96
    I see now. This will help me a lot in tracking things down. Thanks a lot, I appreciate it! Nothing worse than flairing in the wind with no direction!!!
    Aug 2003
    69
    How did it turn out for Publitime?
    I'm curious how things worked out for him. I find myself in a similar position here. Got my board from NC-Step as well.
    Ed.
    Not the horse, of course of course...
    Building my own Scrapheap challenge CNC, or is it Junkyard wars CNC?
  1. Info needed for these servos
    By Splint in forum CNC Machine Related Electronics
    Last Post: 11-10-2008, 10:24 AM
  2. Lathe info needed
    By kong in forum Uncategorised MetalWorking Machines
    Last Post: 06-01-2007, 10:45 PM
  3. Info needed on steppers
    By kayakman in forum DIY CNC Router Table Machines
    Last Post: 12-28-2003, 05:44 PM
  4. info needed
    By turmite in forum DNC Problems and Solutions
    Last Post: 08-02-2003, 07:28 AM
