587,202 active members*
3,084 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > dumb questions maybe, I'm I newbie
Results 1 to 9 of 9
    Feb 2004
    25
    Hey, I am waiting on some plans to build a cnc hobby mill, and wondering when I design a part in CAD, then convert it to G-Code, after that do I just stick it in the CNC control program and tell it to cut, or is ther anything that has to be added into the G-Code to make it cut out the part correctly????
    Thanks allot
    Will
    Apr 2003
    1876
    It will depend on your post and the complexity of the part. Generally, I don't make edits, but many peeps do.
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Sep 2003
    1473
    Welcome
    Here's a link that will anser some of your questions:
    http://www.cuttingedgecnc.com/makingpart.htm
    Check out the rest of the site lots of good information.
    Good luck.
    Hager
    Apr 2003
    1876
    Hager, that's a pretty old link isn't it?
    Step 3- Offset the Part
    The milling machine does not know what size cutter your using until you tell it. It will "trace" the CAD lines and the toolpath must be offset 1/2 of the cutter diameter. You will need to figure out if your converting program will do this for you. If not, which way will the offset be placed so the finished part comes out correct. Notice in the picture, I moved the "offset" path to 0,0 (origin) so I know where to line up the machine for the part later. Also note one of the toolpaths is not offset.
    I haven't seen a program in eons that doesn't do this almost automatically.
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Sep 2003
    1473
    I'm still building, hung up on a part to my Z axis.
    I saw this and thought there was a lot of good information. Sorry if it's out dated.
    I plan on using TurboCNC to start, hope it has all of this.
    Hager
    Apr 2003
    1876
    Just because it's outdated doesn't mean it's useless. There's good info there that still applies. I just thought it was funny about offsetting geometry to the tool's radius.
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Feb 2004
    28
    I once replaced a programmer I was contracted to train at a board shop. He had no CAD tho and was trigging everything out to create the GCODE. He was actually calculating the cutter path. No software used, all input into the controller one charcter at a time.
    Worst part was when I introduced him to G41/G42 and cutter comp tables, he defended his method as being superior because he knew exactly what he'd get. It took all his 1/8" bits away and asked how he'd get the job out with 1/16" bits. "Reprogram" was his reply. That was enough for me. I can tolerate ignorance, but stupidity is too much for me to handle.
    'Rekd
    Nov 2003
    634
    Rekd, As far as I know you have to offset the geometry when you use TurboCNC because it doesn't have cutter comp available, just tool length offsets.
    So the information on the website would be valid.
    T
    Apr 2003
    1876
    T
    Note to self: don't EVER take a job that uses TurrboCNC!
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  1. newbie questions about software/hardware
    By cowanrg in forum Uncategorised MetalWorking Machines
    Last Post: 11-30-2005, 11:45 AM
  2. Newbie Questions
    By Todd Price in forum DIY CNC Router Table Machines
    Last Post: 04-17-2005, 02:31 AM
  3. Newbie questions ?
    By Calico in forum DIY CNC Router Table Machines
    Last Post: 03-31-2005, 06:19 PM
  4. Newbie CAM questions
    By WoodSnarfer in forum Uncategorised CAM Discussion
    Last Post: 11-12-2004, 02:15 PM
  5. Newbie questions
    By NeoMiller in forum Uncategorised CAM Discussion
    Last Post: 11-09-2003, 02:39 AM
