588,124 active members*
5,237 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > NEED ATC PROGRAME FOR CINCINNATI
    Feb 2007
    10
    HI, All Member.
    I Have "Cincinnati Milacron Saber 1000" machining Center with Ge Fanuc OM. (21 Atc Position) I Think in this machine ATC programe was deleted. because when I use "M06 T01" ALAM 078 occur.
    If am I right, I need custom macro atc program for tool change.
    if any member using that machie please help me . My E mail addres.
    "[email protected]" Thanks.
    Oct 2004
    21
    cincinnati millacron saber 1000
    Your prolblem is no prolblem if you call CINCINNATI MILLACRON for the ATC program for your machine. The machine at work lost the hard drive, needed for the all the master program to be uploaded!
    DAVID PONTES
    Aug 2008
    15
    i have send it to u on ur e mail id please run the same and check the same i m using the same system of fanuc..
    take care
    Parveen from india
    Nov 2013
    Help,
    I have a saber 1000 with an Acromatic 2100 Controller I got it a couple months ago and it worked fine for months. Recently I turned it on and I get Application err Application Start up alarm, and it seamed to keep getting stuck on Loading Machine Mode 3. I had read somewhere that my battery on the mother board was dead. I tested it and it was so i replaced it but i still get the alarms. I didn't get any back up disks so IM kind of lost at this point. Can anyone help me?
    Apr 2004
    353
    If you give MAG tech support they should be able to help you out.
  1. DNC on Cincinnati FV 750
    By DHYSTA in forum Fanuc
    Last Post: 02-27-2008, 01:30 PM
  2. cincinnati hawk 150
    By madmike46 in forum Uncategorised MetalWorking Machines
    Last Post: 07-01-2007, 03:16 PM
  3. G96 on a Cincinnati
    By cdlenterprises in forum G-Code Programing
    Last Post: 06-15-2007, 09:31 AM
  4. G96 on a Cincinnati
    By cdlenterprises in forum MetalWork Discussion
    Last Post: 06-14-2007, 10:45 PM
  5. Cincinnati FTV
    By yorel23 in forum Uncategorised MetalWorking Machines
    Last Post: 04-09-2007, 09:24 AM
