588,089 active members*
4,577 visitors online*
    Jan 2008
    26
    Water table question
    Still collecting ideas for my table design. I wanted to have both plasma and O/A but was wondering if you can use O/A with a water table. You would have to at least lower the water level farther from the sheet so as not to splash up and cool the sheet. Would that work or do I need to stay with closing in the bottom of the table and using a vacuum and filter.
    DRL
    Feb 2006
    1260
    I would think water level a few inches low would work ok or table drained all together. O/A doesn't smoke all that bad anyway. You could probably experiment a bit using a cheap cake pan with some water in it & use a hand torch above that. Try 2" above, if you still get to much splash try 3 etc. Should give you some kind of idea how well it would work.
    If it works.....Don't fix it!
    Jan 2008
    26
    Thanks, I like the experiment idea. Most use would be plasma but I should be able to get the O/A to work also. Like you say if all else fails drain all the water.
    DRL
  1. Water Table Question !
    By Pure-Powder in forum Waterjet General Topics
    Last Post: 03-07-2008, 03:09 AM
  2. Water Table or Down Draft
    By hgarwood in forum Waterjet General Topics
    Last Post: 12-25-2007, 06:28 PM
  3. Water Table Question
    By DISCONNECTED in forum Waterjet General Topics
    Last Post: 11-03-2007, 06:58 PM
  4. need water table info
    By massajamesb in forum Waterjet General Topics
    Last Post: 08-25-2007, 06:23 PM
  5. Water transfer techniques for water table?
    By Knut in forum Waterjet General Topics
    Last Post: 02-02-2007, 04:52 PM
