588,495 active members*
5,412 visitors online*
    Feb 2007
    8
    How to calibrate Tool Eye
    Does anyone know how to do a tool eye calibration on a Mazak Super Quick Turn 200MS? Need to do the same on a 250 MSY but it should be the same process.
    We have to offset our X +.032 just to start a job.
    Feb 2006
    992
    Machine B Parameter: B61 for OD and B63 for ID.
    I am not sure you have to minus or plus from B61. For example B61=15344 + 320(320 is equal .032 since no decimal allow). Note: you have to change B63 half of .032(which is .015), if not ID will cut oversize by .032.
    Hope it help.
    The best way to learn is trial error.
    Feb 2007
    8
    Thanks for the info. I couldn't find the parameter in any of my stuff.
  1. How to align/calibrate/install first linear bearing ?
    By Calico in forum DIY CNC Router Table Machines
    Last Post: 10-25-2009, 05:00 PM
  2. How Do I Calibrate MY Centurion 6?
    By TZ250 in forum Uncategorised MetalWorking Machines
    Last Post: 01-13-2007, 04:17 AM
  3. calibrate the motion system
    By webcruiser8 in forum DIY CNC Router Table Machines
    Last Post: 11-27-2006, 09:07 PM
  4. Post your Tips/trick on how to align/calibrate Linear bearing X,Y,Z ?
    Last Post: 04-25-2005, 09:41 AM
