588,500 active members*
5,121 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > stepper motor drives for high amp
Page 1 of 2 12
Results 1 to 20 of 30
    Apr 2004
    20
    Im new here so take it easy on me if i sound stupid. Anyway i have three slow syn unipolar stepper motors i came across that have the following specs.
    2.64 volt
    5.5 amps
    450 hold oz ( thats a lot of torque )
    Looking around i can find somewhat inexpensive drives for low amp but nothing for this high of amperage. I see there is a schematic for a higher amperage drive on this site that can be built somewhat inexpensively and ive built my own curcuit boards a time or two before but they never come out very good . ( they work , well sometimes they do ) Does anyone know of a fairly inexpensive route that i could get some drivers for these motors? Also if anyone here might have an excess of drives that will work on these i can come up with more of these motors and maybe we can work out a trade or something.
    2139
    Sell the steppers on ebay. Buy some that will work with a cheaper drive. What sort of machine you building?
    Eric
    I wish it wouldn't crash.
    Apr 2004
    20
    4 foot by 6 ft router but i figure if i design it properly ill be able to use just about anything as the machine head. And as for selling them on ebay i thought about that but i would also like to take some of these motors and use them to make my lathe and possibly my mill cnc hence the need for torque.
    Sounds like you have some M093-FD11 steppers. Those are excellent motors; hang on to them.
    Mariss
    Apr 2004
    20
    yes those are the motors , pretty pricey to my understanding but i got them for pretty much scrap metal prices, along with some hardened rods and sleeve bearings.
    Jul 2003
    125
    Stepperworld.com's FET-3/4 is capable of handling up to 15 amps.
    2139
    I doubt it. The FETS are RATED at 15 amps, but there are no heatsinks, and no room for any. Also, the circuit board can't handle that kind of current. Also its a unipolar board, so the current limiting resistors needed to get any kind of perfomance would be HUGE. Gecko's are the only cost effective drive for those motors IMHO. You're looking at $345.00 plus powersupply. You would have a nice motor setup mind you.
    I would build first, worry about the drive last.
    Eric
    Apr 2004
    9
    Re: stepper motor drives for high amp
    Check out http:\\www.Stepper3.com
    They sell:
    (S3HPPWM) 3 AXIS 8 Amp Pulse Width Modulated Stepper Motor Driver
    for $369.00 for three axis. Considering that you would need to buy three separate geckos at least $114, its reasonably priced. Note Gecko only sells Bipolar and Servo drives. Although you could use Gecko Bipolar drives to power Unipolar steppers, they will only operate under a fraction of their speed and torque capabilities.
    With this board, you do not need power resistors to drive unipolar steppers. Its also allows you to use separate power supplies for each motor (see the user's manual for details), output power is controlled using on-board potentialmeters.
    I believe that this statement is false. I've never seen anyone who has used both bipolar and unipolar drives recommend the unipolar drives. It seems like bipolar always gives better performance.
    I read the manual, and to calculate the current for the power supplies, you need to take the current rating for each phase of each motor, and add them together. So, (5.5 + 5.5) x 3 motors=33amps MINIMUM. Geckos, on the other hand, are much more efficient, only needing 2/3 of ONE phase rating for each motor. (5.5 x 2/3) x 3 = 11 amps MAXIMUM. This smaller power supply could save you quite a bit of money.
    Another thing is that the Gecko 201's have 10x microstepping, versus 1/2 step for the Stepper3. With microstepping, you'll get much smoother running motors.
    I'd keep the motors and buy Geckos.
    Hopefully Mariss or someone else will step in and provide a more eloquent explanation.
    Mar 2004
    101
    I'll give it a shot.
    The highest torque is developed in bipolar mode due to the fact that the full length of each coil in the stepper are always energized. Whereas in the unipolar mode, the center tap on each coil is used and only 1/2 of each coil is energized.
    As to the question of a bipolar drive and a unipolar motor, that is partly true. You can wire a unipolar motor(6 or 8 wire)as a bipolar, but you can not wire a bipolar motor (4 wire) as a unipolar. A bipolar drive will only drive a bipolar motor and a unipolar drive will only drive a unipolar motor. An 8 wire motor can be more useful because it will allow you to configure the most modes.
    Rvan you are correct that a PWM or chopper drive is more efficient then a linear drive. In order to control current flow, a linear drive will require a bias resistor. The size will be dependent on the Voltage and the current rating of the motor. With the high current motors discribed, the resistor or network would be in the 300-400 watt range. A quick check at Digikey will show that to handle that much power will cost a arm and a leg.
    By and large the most cost effective and powerful setup would be a bipolar chopper or PWM drive system.
    Hope this helps,
    Bill
    If it helps, you can use the following as a means of calculating how much bang you get for your buck. It applies as a rough measure to all drives you may be considering:
    Value = (Max Amps times Max Supply Voltage) / Price
    Example: G201 is (7A times 80VDC) / $114 = 560 / 114 = 4.91
    The bigger the number, the better the value for your money. Try this on some other drives and see what number you get.
    Another one might be (2Amps times 36V) / $35 = 72/35 = 2.06
    You are getting about 40% for your money with that one.
    This number does not take into account microstepping, midband compensation and other factors that enhance a drive's utility.
    Mariss
    Sep 2003
    22
    Hey that's a pretty reasonable value formula. It works out to power delivery per dollar. I like it!!
    Eldon.
    2139
    Of course, if you are running 1 amp motors, with some drives you may be paying for un-needed "value". Like using an elephant to step on a fly when you could have used a fly swatter, and the fly swatter is cheaper. A fly swatter cant kill a bear, but you only have flies to kill, no bears. OTOH, this is not the case with the motors mentioned above, they are bears.
    Eric
    Nov 2003
    244
    Check this link out http://electronickits.com/kit/complete/motor/ck1406.htm
    6 amp bipolar $19.95 it is in kit form and I 'm going to substitute the fets with irf540's and irf9540's the one that come with it are 60 volt 12amp on the low side and the irf9540n is 23amp at 100volt = cooler running
    ...He who makes no mistakes makes nothing! ...
    Tom
    Apr 2004
    678
    And what is restricting the current into your motors?
    Too much current over time will cook the motors. If way too much it will demagnetize the motors and this will happen in microseconds, so even if the power supply is current limited, just the capacitors after this limiter may have stored enough energy to do that.
    2139
    If you run the motors at rated voltage, the windings restrict the current.
    If run at over the rated volatge, you need current limiting build into the drive or external resistors in series with the motor.
    Tpworks,
    That drive is not a chopper drive. It will need external resistors to limit the current unless you run at rated voltage. For high current motors these can really be expensive. What motors will you run? what voltage power supply?
    Eric
    Apr 2004
    9
    I think you misunderstood me. He said he purchased "Unipolar" steppers. If you use a Bipolar driver board (like Geckos) with Unipolar steppers they will have to be operated under reduced power or speed (from the Gecko User's manual). I wasn't comparing efficiencies between Bipolar and Unipolar motors.
    [/B]
    All I said here was that you have the option to use multiple supplies if need to with the Stepper3 driver board. Most if not all 3 or 4 axis drivers only permit you to use one power supply. If for instance you wanted to mix different steppers (requiring different voltages), you could do it with the stepper3 board. Of course using a single power supply would be the best option, but In some cases it can be cheaper and easier to find two or three smaller Power supplies than one larger one.
    Maybe I did misunderstand what you said, but I still disagree with what you are saying now. Here is what the Gecko manual says:
    4-wire, 6-wire and 8-wire motor may be used. When 6-wire motors are used, they may be connected in half winding or full
    winding. This is equivalent to an 8-wire motor connected in parallel or series. If a motor is connected in series or full winding, the
    motor’s phase current rating is half of its parallel or unipolar rating. The choice depends on the high-speed performance required;
    a parallel-connected motor will provide twice the power of a series-connected motor at the same power supply voltage.
    A 6 wire motor will still be able to develop it's full rated torque using a Gecko. The manual doesn't say anything about reduced power, except when wired full winding at high speeds. An 8 wire motor wired series is no different.
    On the power supply thing, I think you misunderstood me. What I was saying, is that the Stepper3 board would need a power supply that delivered 3x the current of a power supply for the Geckos.
    I'm only posting the info that I've read. If I'm wrong, someone please correct me.
    Mar 2004
    101
    If I may, Gerry you are absoultly correct. The greatest torque is developed in bipolar mode. As quoted above, the best preformance is parallel bipolar, with also the highest current demand. The holding torque is the same for parallel or series bipolar, but the torque of a series bipolar drops at a greater rate as the RPMs increase. Both the parallel and series bipolar modes have a higher holding torque then unipolar due to the use of the full length of the coil, with the exception of half-winding bipolar which has the same holding torque of unipolar. As an example, below is from the http://www.pacsci.com/support/docume...r/stepsel.pdf, Pacific Scientific showing the relationalship of the winding modes (half-winding bipolar is not noted here).
    Mode Model holding torque Current/Phase Phase resistence
    Oz/In (Nm) Amps DC Ohms
    Par bipolar P2HNXXH-LXX-XX-00 • 59 (0.42) 5.2 0.22
    Ser bipolar P2HNXXH-LXX-XX-00 • 59 (0.42) 2.6 0.90
    Unipolar P2HNXXH-LXX-XX-00 • 42 (0.29) 3.68 0.44
    I had posted before that an 8 wire motor allows the greatest flexability, this is because there is no internal connection at the center tap of the phase coils. The user can choose to make the connections as parallel bipolar, series bipolar or unipolar. The user has the option to match the motor to the drive.
    Bill
    Mar 2004
    101
    Well, I see that the formating for the info I posted was lost, sorry. The quoted numbers for each mode are: Oz/in (Nm) AmpsDC Ohms.
    Bill
Page 1 of 2 12
  1. Question about 6 amp stepper motor
    By Yellowbeard in forum Stepper Motors / Drives
    Last Post: 04-20-2005, 02:51 AM
  2. Stepper Motor High Torque Low Amp
    By Sanghera in forum Stepper Motors / Drives
    Last Post: 03-22-2005, 01:16 AM
  3. Need a low cost 4 amp, 48 volt, stepper drive
    By Mini Miller in forum Stepper Motors / Drives
    Last Post: 12-15-2004, 08:29 PM
  4. Not good for a stepper motor?
    By FLUTE HEAD in forum Stepper Motors / Drives
    Last Post: 12-02-2004, 06:31 AM
  5. Fun with floppy stepper and driver
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 03-08-2004, 08:18 AM
