587,997 active members*
2,318 visitors online*
    Jun 2014
    49
    Increased feedrate, getting rounded corners
    I've been trying to cut down the time it takes to do some large rotary work jobs and wanted to increase my feedrate. I increased a job's feedrate and wound up getting curves in the corners that should be square when rouging. I increased the acceleration and the problem goes away, but I start missing steps because the acceleration is too high. I'd like to keep my accelerations low and my velocities higher. It seems like mach 3 moves on to the next line of gcode before the previous line decelerates and finishes fully.
    I have motion control set to CV. I'm wondering if this is my problem. Thanks for any help you could offer.
    Re: Increased feedrate, getting rounded corners
    CV is Constant Velocity mode. In order to try and maintain Constant Velocity, mach3 has to round the corners, as you've noticed.
    You can try using "Stop CV on angles" to set it to keep some corners square, and still have decent speed. Turning of CV mode will probably not give very desirable results.
    - - - Updated - - -
  1. Feedrate override vs programming a faster feedrate?
    By Zeppelin1007 in forum Mach Software (ArtSoft software)
    Last Post: 01-11-2013, 10:38 PM
  2. rounded corners when pcb milling
    By jpm000001 in forum LinuxCNC (formerly EMC2)
    Last Post: 04-09-2012, 08:38 PM
  3. square corners getting rounded off
    By SatanKlawz in forum Uncategorised CAM Discussion
    Last Post: 06-30-2010, 02:33 AM
  4. rounded corners
    By jc286006 in forum Uncategorised CAM Discussion
    Last Post: 06-25-2006, 06:04 PM
  5. Rounded corners...
    By saturnnights in forum SheetCam
    Last Post: 02-13-2006, 08:06 PM
