588,554 active members*
5,428 visitors online*
IndustryArena Forum > CAM Software > UG NX > NX7 3+2 axis toolpath
    Oct 2009
    I would like to generate a toolpath for a 5 axis milling machine with two axis swivel head (B and C axis). I would like a toolpath with B and C axis rotated and locked and the stopovers applied in Z-axis direction. The thing is that if I use the Z level profile and rotate the B and C axis the stepover is applied in direction of tool axis which generates the movement of all three linear axis. I want to have a movement of only the X and Y axis and the movement of the Z only between the cut levels.
    I hope someone knows what I mean and can give me a push in right direction!
    Luka from Slovenia
    Aug 2008
    71
    I thnk you are looking for zlevel_5axis.
    Mark Rief
    Siemens PLM
    Feb 2006
    992
    I'm not sure what you want.... 3+2 is same idea as 3 axis milling except you are index the part to mill on angle ......
    Hope it's help.
    The best way to learn is trial error.
    Oct 2007
    41
    Z-level 5-axis will get you close, but it still wants to change the tool axis in the middle of the path. Mark, is there a way to lock the axis?
    "Of course, that's just my opinion. I could be wrong!"
    T Briggs (CAM dude) - Siemens PLM Software
  1. Toolpath in 4th axis
    By cncuser1 in forum Mastercam
    Last Post: 06-14-2009, 12:18 AM
  2. 4 axis mastercam toolpath
    By podgee in forum Canadian Club House
    Last Post: 05-06-2009, 05:08 PM
  3. 4 -axis toolpath?
    By Stebedeff in forum Mastercam
    Last Post: 04-26-2009, 08:16 PM
  4. 4-5 axis milling toolpath
    By aldebaran07 in forum Mastercam
    Last Post: 05-21-2007, 02:42 PM
  5. 4th Axis Toolpath with mastercam
    By rcrabb in forum DIY CNC Router Table Machines
    Last Post: 01-07-2007, 03:41 AM
