588,621 active members*
5,810 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Has anyone disassembled a Tormach into subassy to make a difficult move in?
Results 1 to 6 of 6
    Mar 2005
    181
    I'm strongly considering buying a Tormach PCNC. Unfortunately I've got a difficult location on the 2nd floor accessible only through a narrow stairway that leads to a hallway which is narrowed to an annoying 32" width.
    Has anyone brought in their Tormach by disassembling it into major sub assemblies? I'm guessing that the cross slide table assembly is going to be the heaviest. Could anyone guestimate how heavy the table ass'y is? Could 4 strong people lug it up a flight of stairs?
    Jun 2006
    2512
    This has been discussed a number of times. Search this group plus here:
    http://groups.yahoo.com/group/tormac...guid=239385462
    Also the Tormach web site has info on moving in confined spaces.
    Phil
    Quote Originally Posted by MadMax View Post
    Mar 2007
    18
    Best disassembly write-up I have seen
    The best write up of a tormach disassembly and move (including some weight information for the parts) is at: http://memweb.newsguy.com/~mphenry/tormach_cnc_mill.htm
    Lots of information and lots of pictures.
    Nov 2004
    284
    Take a look at Mikes web site below. He has documented moving a Tormach into his Basement. Gives you a good idea of what is involved with a move like this. The chunks are large and very heavy so be careful and take your time. Here's Mikes Web Site:
    I would strongly recommend verifying all Inspection Items from your Certificate of Inspection Sheet before disassembly and after re-assembling your Mill. That way you will be sure that your Mill is back into correct alignment as it was before moving it into your Basement. Here is an example of a Certificate of Inspection Sheet:
    http://www.tormach.com/document_libr...Inspect_V3.pdf
    Mike is a very knowledgable fellow and willing to help. Give him a shout if you have any questions on his move.
    Regards
    Willy
    Mar 2005
    181
    Excellent informative replies! Thanks! Mike's page is very well detailed.
    Jun 2006
    3063
    MadMax,
    Ask here or on the Yahoo group if you have any questions. Email is OK too.
    Mike
  1. Why is EVERYTHING so difficult?!? (meshcam / SW hate)
    By ClemsonGirl in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-23-2008, 05:04 AM
  2. Cant make it move
    By hugo carradini in forum CNC Machine Related Electronics
    Last Post: 10-12-2007, 11:50 PM
  3. Security/marking compound to know if parts were disassembled?
    By SRT Mike in forum MetalWork Discussion
    Last Post: 11-09-2006, 01:49 AM
  4. Difficult Lathe Fixture Problem
    By seco in forum Uncategorised MetalWorking Machines
    Last Post: 09-22-2006, 05:02 PM
  5. How difficult is it to add a tool changer to a TM-1?
    By KevinWilkins in forum Haas Mills
    Last Post: 05-03-2006, 05:01 PM
