I'm starting a new build an an integral part of that build is a 3" torsion box. I have never built one before and have been viewing different techniques, mostly on wood working sites. However, they all seem to emphasis the need to construct the box on a level surface and they go to great lengths to do so.
I feel like I am missing something. The way I see it is if all the ribs and sides are cut to exactly the same height and glue is applied to all the mating surfaces, when you apply the skin and nail it together with a pneumatic nailer, all the surfaces will pull tight and it will be flat and level to the skin. I think you should be able to assemble it on a gravel driveway if you wanted.
Does anyone have experience building one and did you go to great lengths to ensure a flat building surface?
