586,111 active members*
3,522 visitors online*
IndustryArena Forum > Hobby Projects > Steam and Stirling Engines > low friction and low temp packing question
Results 1 to 3 of 3
    Nov 2004
    202
    Smile low friction and low temp packing question
    I have got to set up with a display engine that will run on low pressure air.
    Pressure will be less than 5 psi so I am looking for a packing material that has low friction, but still has reasonably low leakage.
    Cheap is good too.
    Any suggestions?
    Thanks,
    Bob B.
    Oct 2005
    2392
    Delrin (polyacetal) would be my choice for a small air engine. Besides being good for highish temps (>100'C high for plastic) it is springy and allowing for that can be made into its own seal that doesn't need lube. Its very slippery on polished metal.
    Something like a cupped piston would work fine as the cupped part could be thin walled and the springyness of the material (maybe compined with the air pressure) would make it a good seal, without the drag of orings or other seals. Its a plastic commonly used in small pump and valve type devices because of those properties.
    Nov 2004
    202
    Quote Originally Posted by RomanLini View Post
    Thank you,
    Thanks sounds like exactly what I'm looking for.
    I have already located a source and will order some tomorrow.
    (Today is a Holiday here.)
    Cheers,
    Bob B.
  1. Is this foam packing on laser tube?
    By LaserGrl in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-11-2011, 03:34 AM
  2. Packing a ball nut
    By nateman_doo in forum Benchtop Machines
    Last Post: 01-19-2011, 08:19 AM
  3. A fine Harbor Freight packing job!!!
    By ZipSnipe in forum Benchtop Machines
    Last Post: 04-23-2009, 12:57 PM
  4. Coefficient of Friction
    By TZ250 in forum Mechanical Calculations/Engineering Design
    Last Post: 06-28-2008, 05:59 PM
  5. spindle temp, motor temp.
    By nervis1 in forum Uncategorised MetalWorking Machines
    Last Post: 07-20-2004, 03:09 PM
