587,256 active members*
2,786 visitors online*
    Jan 2008
    78
    G71 problem on Fanuc 15-TF
    Trying to start using G71 multi-repetitive cycle on Puma 8HC turning center.
    This is simple code I am trying:
    Code:
    G20 G90 M17
    G28 U0. W0. T0600 S600
    M42
    G50 S2000
    G57
    M03
    (TURNING TOOL #6)
    G0 X2.2 Z.2 T0606
    (TOOL CLEAR OF PART)
    G96 G99
    G71 P100 Q101 D.05 U.02 W.02 F.010
    N100 X.5 Z0.0
    X0.7 Z-.45
    Z-.105
    X1.25
    G03 X1.75 Z-1.55 R.5
    G01 Z-2.5
    N101 X2.2
    M05
    M30
    When the G71 line is executed I get alarm: "Illegal use of decimal point"
    Can anyone tell me what I am doing wrong?
    Cheers,
    Steve E
    Nov 2013
    65
    Re: G71 problem on Fanuc 15-TF
    Apparently it's not liking one of the decimals in one of the variables in the canned cycle.
    See if it runs this way?
    G71 P100 Q101 DO5OO U0200 W0200 F0100
    You need a G1 in the N100 line.
    I don't understand the Z-.105 move. Is it a typo?
    Brent
    May 2016
    526
    Try
    G71 P100 Q101 D05 U.02 W.02 F.010
    If that doesnt work try taking the point out on feed
    If you send me your email I'll send you the manual
    Jan 2008
    78
    Quote Originally Posted by yardbird1969 View Post
    Brent
    Yup, that was a typo. It should be Z-1.05 So I'll try that & see what happens, and if that doesn't work I'll remove the decimal points as suggested.
    Cheers,
    Steve E
    Jan 2008
    78
    My control did NOT like decimal point for the 'Dxx' parameter. I had to use 'D0500' for a .050" deep rough pass.
    Here is my working code:
    G20 G90 M17
    M42
    G50 S2000
    G57
    (TURNING TOOL #6)
    G0 X2.2 Z.2 T0606
    G96 G99
    M03
    G01 U0. W0. F0.01
    G71 P100 Q101 U0.01 W0.010 F0.01 D0500
    N100 G01 X.5 Z0.0 F0.005
    X1.0 Z-.45
    Z-1.05
    X1.25
    G01 Z-2.0
    N101 X2.2
    G70 P100 Q101
    M05
    M30
    Thanks for the guidance.
    Cheers,
    Steve E
  1. Problem Fanuc 18-T
    By Shukman in forum Fanuc
    Last Post: 08-12-2016, 03:32 PM
  2. FANUC 11M-A problem
    By Fred_Hony in forum Fanuc
    Last Post: 02-17-2015, 07:36 PM
  3. PMC problem with Fanuc 18i TB
    By Ahmed18 in forum Fanuc
    Last Post: 09-15-2013, 02:36 PM
  4. Problem with fanuc 01
    By dopamine in forum Fanuc
    Last Post: 04-11-2010, 04:31 AM
  5. Fanuc 6T problem
    By gridley51 in forum Fanuc
    Last Post: 01-14-2008, 06:39 PM
