588,597 active members*
12,453 visitors online*
    Aug 2004
    15
    Need help for CNC milling set up
    Hello:
    After measuring machined part, I need to make a ajustment to G54, X,Y,Z. I don't know which direction I should move G54,X,Y,Z. when I should Plus or minus?
    Thanks for help.
    Apr 2003
    1873
    a00509265, a00509265 ain't no name
    Z setting would be the top of part after fixturing.
    work offset X,Y would be oriented to match the X0 and y0 position in your cad.
    I almost always position square or rectangle parts in the Y- and X- quadrant in the cad, like the PIC.
    In the next Pic this is how you would place it in a vise the Black block being the non-movable jaw.
    SO G54 X would be set to the right face of the green block
    and the Y set to the back face of the green block
    Hope this helps.
  1. Thread milling, can anyone help
    By jtrav in forum Uncategorised CAM Discussion
    Last Post: 03-06-2006, 09:25 PM
  2. Why would this machine be bad for milling?
    By jevs in forum Knee Vertical Mills
    Last Post: 06-17-2005, 04:49 AM
  3. Heads Up - Article about building CNC Milling Machine
    By samualt in forum Community Club House
    Last Post: 06-13-2005, 08:43 PM
  4. Replies: 5
    Last Post: 05-29-2005, 03:17 AM
