587,733 active members*
3,127 visitors online*
    Sep 2007
    14
    Limit switch rated voltage?
    I am on a project of building a 3-axis CNC milling machine. I have purchased the breakout board from CNC 4 PC, stepper motors and gecko drives G203V. I am using MACH 3 as the software, so I'm using the parallel port to send out commands (PWM of 5V).
    When I read the data sheet for limit switches I found from RS Australia, the rated voltage is usually 8, 14, 30 and upto 250 VDC. Where do I get these voltage supplies? Initially I thought the limit switches will be powered by the 5V on the parallel port. How should the limit switches get power from, the parallel port, or some other power supplies?
    Lastly, do you guys have any good supplies of limit switches? I am looking for $10 to $30 and I might need 6 of them.
    Thanks in advance!
    May 2006
    1469
    The switch voltage rating is just a maximum.
    Most home builders will run their limits on 5v with the BOB providing either optoisolation or buffering.
    There are other ways to do it. I personally run mine on twelve volts (I already had that handy in the control box running fans)
    This can help with noise issues on normaly closed limits. Most industrial applications run them on 24v.
    But I would not worry about that at your stage of building.
    In fact most of the blokes I know here in Aus with homebuilt routers are quite happy with no limit switches at all.
    Have a look at this ebay seller. They have a range of limit switches.
    http://stores.ebay.com.au/Claraworld...QQftidZ2QQtZkm
    Greg
    May 2006
    2420
    Quote Originally Posted by Greolt View Post
    Hey, I have limit switches...erm... in a drawer somewhere (chair)
    I did install one on the X axis... one day I may even connect it to something Besides servo's are much more fun to play with !
    Russell.
  1. Is it possible to use the home switch as the limit switch as well?
    By Darc in forum Mach Software (ArtSoft software)
    Last Post: 11-02-2012, 06:25 PM
  2. When to switch on motor voltage to G201
    By hecirp in forum Gecko Drives
    Last Post: 09-19-2007, 02:34 AM
  3. limit switch and home switch setup
    By Runner4404spd in forum CNC Machine Related Electronics
    Last Post: 12-15-2005, 02:58 PM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
