587,262 active members*
3,613 visitors online*
    Feb 2004
    35
    Rated BLAC servo RPM
    I have a new baldor brushless ac servo, bsm80b, and the rated max rpm on it is 4000. I want to use it as a spindle motor and was wondering if these motors can be driven past their rated rpm and how far. I am looking to reach 6000 if it is safe for the motor. Any suggestions??
    Jun 2003
    866
    Given a blank sheet of paper, you probably can drive it past its rated rpm. Since you need a driver to commutate the motor, you probably will not be able to do it. The other thing you need is more voltage than it's rated for because just like a brushed pm motor, the speed depends on voltage
  1. Small servo systems and power supply
    By imserv in forum News Announcements
    Last Post: 04-03-2008, 05:11 PM
  2. Motor calculations
    By jevs in forum CNC Machine Related Electronics
    Last Post: 03-21-2005, 08:05 PM
  3. Help evaluating this servo motor
    By WoodSnarfer in forum Servo Motors / Drives
    Last Post: 02-05-2005, 09:51 PM
  4. What is high speed machining
    By johnm in forum Hard / High Speed Machining
    Last Post: 12-29-2004, 11:41 AM
  5. Brushed servo drive replacement
    By motordude in forum CNC Machine Related Electronics
    Last Post: 07-06-2004, 07:09 PM
