I managed to get the test cast out of the tube and found an interesting variation in the cross section composition.
The cast end photo shows a increase in the sand toward the middle, so I broke off the other end of the test piece as it was very starved of resin. The result showed an unexpected sudden change in resin/particle size about half way out toward the center.
I'm not sure if it's just a sudden change in the resin percentage or a variation in the particle size of the aggregate or both.
The only observation that might be relevant was that there would be an initial excess of resin at that end of the mold before spinning commenced.
Once it started, the resin would have migrated outward and along the outer face of the mold, and drained that part of the center. This would leave resin bound to the surface of the sand sufficient to bind that part into a mass, but probably with a fair bit of air present, showing up as a lighter color in the central part of the sample.
Having had a bit of a problem extracting the sample, I'm going to have to come up with a design for a split mold. That should be fun.
John
It's like doing jigsaw puzzles in the dark.
Enjoy today's problems, for tomorrow's may be worse.
