588,112 active members*
5,574 visitors online*
Results 1 to 13 of 13
    Jan 2007
    311
    Material removal, pondering
    I just ran a quick one-shot job off the 1100.
    A dozen CRS (1020 ?) steel blocks. needed a slot taken across them in the middle. Blocks were 3" long, 1-1/2 wide and about 1" thick. The slot was across the 1-1/2 axis, 1-3/8 wide and .400 deep.
    3/8 dia 4fl coated endmill, 1.25 sticking out. (what I had available, pretty much new)
    Now normally I run aluminum and stainless (300 & 400 series) so it's one end of the spectrum and the other. These steel parts were an oddity so I played with Gwizard and come up with .050" DOC, 3000RPM and 5ipm feed
    On the machine I ended up bringing the rpm down to 2200 and the feed to 3.6 to get a decent sounding cut. Now the first path through was full slot width and each one after was .260 width so I could have stepped it up but I just ran the pieces off.
    Cycle time ended up somewhere near 18 minutes per.
    Anyway, parts are done and gone and it's no big deal, just seems pretty excessive but was curious how others would have approached this
    M
    Dec 2013
    5722
    Re: Material removal, pondering
    Depending on the finish required, I would have grabbed a 1/2 inch cobalt finishing rougher, 0.400 DOC, 2 IPM, 0.240 stepover, about 700 RPM, mist coolant with excess air to blow the chips out.
    Sep 2009
    624
    Take a look at NYCCNC's video about cutting 4140 and optimizing. My go-to starting point with CRS is 1/4" carbide 4flute with a corner radius, 1800 rpm, 6-7 ipm, 0.07 woc, and .2-.3 or more doc. You were initially slotting, so that needs some adjustment. My overall take on the video is go deeper but narrow rather than wider and shallow, and keep speed and rpm in the ballpark of 300 rpm per ipm (in steel). That has worked for me. Either speed range seems to work OK.
    Saunders was doing about .25 doc, 3500 rpm, and around 0.1-.2 woc at roughly 15 ipm. NOT slotting.
    https://www.youtube.com/watch?v=7kkx6JFUDFI
    If I did the math right, that'd bee 14 full depth passes (1 inch/0.07 per pass) at about 15 sec/pass at full depth, or about 4 minutes, vs 4 passes (1"/.260)x 8 (.4/.05) or 32 passes at 30 sec per, which is 16 minutes. Plus the initial slotting pass in both cases. Math seems to match your actual within reason, so it may be right.
    For what it's worth.
    Jan 2007
    311
    I was actually trying to get my mastercam to deal with the trochoidal or HS looping path for this slot as I programmed it but it kept creating this weird D shaped path so after playing for a few minutes I just went ahead with a zig-zag regular path to get the parts done.
    I'll have to experiment more and see but I get the feeling that my old X2 version was before they really started with the HS paths.
    M
    Feb 2006
    7063
    Quote Originally Posted by Mooser View Post
    M
    Trochoidal paths ARE D-shaped, cutting on the curved side, doing a straight rapid back to the start of the next pass...
    Regards,
    Ray L.
    Jan 2007
    311
    Yes, guess I should have worded that better.
    It kept trying to do it in the middle of the slot outwards, my problem but I usually struggle with open-ended slots in MC and ended up creating a closed slot, which is why I'm guessing it was trying to work from the center out. I keep meaning to figure out how to do open slots properly but then forget about it until it pops up again...
    M
    Jul 2012
    118
    i like using varimills and run them at the suggested speeds and feeds. i would use 1/2 4 flute with champer corners. about 3800 rpm and feed of 38 ipm, about .3-.4 doc... works well. then i would use a new varimill for finish...
    Jun 2012
    311
    Mooser,
    Your chipload seems too light. 3000rpm, 4flute, 5ipm works out to .0004 ipt.
    I would slot with HSM paths at full depth, but getting that right takes a lot more work, and when you have to get the job done now isn't the time to figure it out.
    Aug 2009
    106
    For a slot that wide, just use an HSM/adaptive roughing path with a smaller cutter.
    1/4" 4fl carbide (short flute: 1/2" LOC), 3600 RPM, 80 IPM, 0.012 WOC, 0.4 DOC (230 SFM, 0.0013 chip)
    Should do your slot in about 3 min. I just ran the same path last night with my 770 on Titanium, Stainless, and Zirconium so it should work for 1020 no prob. Probably even kick up the SFM another 100+. I also let the cutter run in both directions so there's no D-shaped paths, the cutter stays in the cut the whole time.
    --Bryan
    Jun 2012
    311
    Bryan,
    Look at your numbers again. 3600rpm, 80IPM 4fl results in .0055ipt. Chip thinning with a .250dia and .012WOC results in a chip thickness of .0025
    To get a chip thickness of .0013 you need .003ipt. Feedrate of 43.2ipm at 3600rpm
    BTW, Great job on your FS calculator. I use it regularly.
    Aug 2009
    106
    IMT - Thanks! Glad it is helpful, I've been using it almost exclusively for a couple years.
    I'm quoting numbers from a different version of the calculator, it's got new equations for HSM. Since you point it out, I'll check the math and see if I mucked something up! ;-) It uses a scale factor for chipload, as well as an equation for average-chip thickness (instead of initial chip-thickness) which works better for the extremes of the scale that you run into using HSM. The average chip thickness gives you a thinner chip under most conditions, so the calculator offers a higher feed rate, which translates into higher MRR.
    Some of Widia's recommendations are quite clever, though I haven't decided to fully switch over to their model yet. Their model is nice because it works for any material if you know its hardness, no need for the magic "power constant" used by the classic model.
    --Bryan
    Jan 2007
    311
    OK So now I'm curious and I'll have to try
    I've got a little bracket piece to make (2 pieces) that is also 1020, looks like half circle with two flanges, where each would go together with a bolt through each flange and clamp around a 1" dia pipe
    Going to contour around the outside, total depth is .7"
    Material in a vise sticking out .750, holding onto .625 in the vise (material I have in hand)
    I've got the same .375 4fl carbide endmill, tialn coated
    Loaded HSMexpress for solidworks since I didn't have much luck with MC
    Plugged in a bunch of stuff and came up with .250 DOC, 4000 RPM and 20ipm stepping over .05 each path, climb milling
    With the given 3/8 EM, what would you think the WOC should be? I'm thinking I'd like to see something closer to .01, maybe with a DOC closer to .4 (two steps) or even full?
    Input?
    Jan 2007
    311
    So it more or less actually worked
    Adaptive clearing .700 DOC, .025 WOC, 4500 RPM, 20ipm (tried 30 and ended up bringing the feed override down to 65% where it sounded like a happy cut)
    Finish pass contour .700 DOC, 010 WOC 4500 RPM 13 IPM with 1 spring pass leaving a nice finish and no chatter even on the inside corners (.200 Rad with the .1875 rad cutter)
    I'm fairly impressed with how that worked, not very aggressive and I'll have to check my "old" way to compare times.
    Now to look at open ended slots....
    M
  1. Most Efficient Material Removal Method
    By cncClintain in forum Mastercam
    Last Post: 06-08-2011, 02:06 PM
  2. Replies: 2
    Last Post: 05-28-2009, 08:01 PM
  3. Extra Material Removal...Help
    By Cartierusm in forum ArtCam Pro
    Last Post: 08-01-2008, 12:56 AM
  4. removal of 4140 HR Annealed material
    By Zipdrive in forum MetalWork Discussion
    Last Post: 01-12-2006, 05:51 AM
  5. material removal / air blower help
    By DrStein99 in forum DIY CNC Router Table Machines
    Last Post: 10-21-2005, 01:49 PM
