588,342 active members*
5,317 visitors online*
    Feb 2007
    5
    Boundry Cuts?
    Im new to bobcad-cam and I go a a vocational school where we are using bobcad and a 1984 Bridgeport Mill....Ive been playing around and so far Ive been trying to cut a 9x7 superman logo on our mill...but my question is how do I cut it out just in the boundry instead of the ENIRE 9x7 square??
    thanks
    Feb 2007
    514
    I don't know much yet about bobcad but Sorin's videos helped me get over the learning curve...
    Based on my limited knowlage of BC you need to pick the tool path and do a tool comp to keep the tool on the outside of the line... Hope someone that knows more will chime in...
    John
    Aug 2003
    449
    Well if you are trying to cut it so that the superman logo is left standing then you are going to need to pocket and profile the logo.
    If you are just trying to mill the logo into the material then all you should need to do is pocket the shape.
    Pocket the Whole thing:
    Select the outside shape so that the arrows are going Counter Clockwise.
    Then Select the inside shapes so that the arrows are all going Clockwise.
    Click on Other and then Pocket.
    I would suggest a spiral at this point.
    Input the values for the Tool daimeter and Step over distance you want to use.
    Click OK.
    The Pocket "Should" generate.
    Next thing is to open the NC-CAM window.
    Do your program start and Tool change if needed.
    Click on the button with the "u...d..." on it and fill in the depth information.
    The Toolpath should still be selected at this point. If it isn't then you may want to review the video on Machine Auto(can't remember which one it is though).
    Left Click on Machine Auto.
    Then program end and your done.
    Regards
    Oct 2005
    859
    Are you wanting to limit the tool path to the logo edge on a solid?
    If so draw a boundry. If this is a solid then you can extract the edges and use that.
  1. More first cuts
    By cncadmin in forum DIY CNC Router Table Machines
    Last Post: 11-27-2006, 05:00 PM
  2. More first cuts
    By wcarrothers1 in forum DIY CNC Router Table Machines
    Last Post: 11-25-2006, 02:19 PM
  3. First cuts
    Last Post: 10-27-2006, 05:17 PM
  4. First cuts
    By no priors in forum MetalWork Discussion
    Last Post: 08-21-2006, 04:03 PM
  5. angle cuts
    By coolman in forum MetalWork Discussion
    Last Post: 01-23-2005, 06:33 AM
