587,997 active members*
1,830 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > HELICAL INTERPOLATION in FANUC -OMC
    Aug 2007
    6
    DEAR ALL ,
    my cotroler fanuc omc can't run in helical interpolation , please help me .
    best regards .
    Aug 2007
    339
    You must have an older machine cause I think all the newer ones can do helical interpolation. So you can't do it? Find a different way to do your Bores then. You can drill a center hole for tool clearence then send your cutter in there and circle interpolate the bore. Come back to center and do it again till you get to depth. Then send in a finish tool to bring it to size using circle interpolation. Short of buying a new machine you'll never get helical interpolation on that.
  1. Fanuc 16i-m Helical Interpolation Problem
    By Goran P. in forum Fanuc
    Last Post: 03-27-2009, 08:41 AM
  2. HELICAL INTERPOLATION in FANUC -OMC
    By TONY252 in forum Fanuc
    Last Post: 08-22-2007, 06:27 AM
  3. helical interpolation parameter
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-15-2007, 12:10 AM
  4. Fanuc 11M Helical Interpolation
    By MrMagooo in forum Fanuc
    Last Post: 11-15-2006, 04:58 PM
  5. Helical Interpolation
    By dbcoop11 in forum Bridgeport / Hardinge Mills
    Last Post: 12-31-2004, 05:15 PM
