In my V23 build 1595, which has been working great since first installed when it was new, now suddenly is popping up an error whenever I try to generate any 3D toolpath.
"Security Failure 4" When I click the OK button then another pops up saying "Access Denied".
After the OK is clicked in the Access Denied error window then the Security Failure 4 pops up again followed once again by the Access Denied.
This happens with both existing and new files, but only on 3D paths. 2D paths work fine.
I receive the same sequence of errors when connected and disconnected to the network/internet.
I have the same results with and without the dongle connected.
My LICENSE shows the correct levels.... CAD 1, MILL 3, ART 1, OTHER 3. The other information on the license page is complete and correct.
I tried a repair install. Nothing changed same errors.
I tried uninstalling both Bob and Preditor from Windows Add/ Remove, reboot and reinstall from the full install build 1595 file. Nothing changed same errors.
I tried uninstalling both using the build 1595 installer, choosing the uninstall option. Then reboot and reinstalling 1595. Nothing changed same errors.
Then I uninstalled both with 1595 installer, removed all traces of both from the registry, reboot then did full install from 1595 installer. Nothing changed same errors.
As I said, Bobcad has been working fine with no problems at all and suddenly it has gone haywire.
No new programs installed, no new updates added since the last time it worked correctly.
Any Ideas?
Thanks!
