588,487 active members*
5,935 visitors online*
    Nov 2015
    13
    Depth of Z-axis.
    Hey,
    I've never done a 'poll' before so I hope this works.
    So I am trying to build a design for a small/medium size machine (a little shy of a 47" x 24 " build area)--
    But, since I've never had one of these things to play with before, I am wondering what is a 'reasonable' figure for my Z-Axis ?
    Of course perhaps more of everything is always better, though I mean within reason for most jobs.
    I am not sure thus taking inquiries.
    Nov 2013
    4609
    Re: Depth of Z-axis.
    I built a mill, that is to say a C column machine, hopefully rigid enough to cut steel, even if carefully. It weighs about 800kg. Its travels are 350mm x 350mm x 350mm.
    Plenty of Z axis travel is desirable, especially if you ever want to install a fourth axis, they soak up so much travel. With gantry machines however large Z axis travel is very VERY hard to
    secure WITHOUT causing large and unwanted flexure of the gantry. Its a balancing act.
    Craig
    Nov 2015
    13
    @joeaverage I have a bunch of these to play with. They were originally designed for something completely else-- But they are also hollow in the welds, so I think a granite sink is possible.
    In any case my goal is to do the best with what I happen to have:
    https://photos.app.goo.gl/RbeXvtpXkrT6Msra7
    Jan 2008
    1543
    What are you cutting? That is the primary decider.
    Sheet goods up to 25mm thick? Then a short Z axis/low gantry height.
    Remember you need enough for workpiece, tool length, tool holder length.
    Milling machine for metal? Much larger Z axis travel.
    Need to account for vice / workholding, often thicker/taller workpiece
    Nov 2015
    13
    @pippin88 thank you for the mention about the vice-- That is not something I immediately worked in, and again why I asked.
  1. Replies: 1
    Last Post: 07-09-2018, 05:47 AM
  2. Artgrave 2002 - depth on Z-axis - how to?
    By simonx in forum ArtCam Pro
    Last Post: 08-15-2015, 10:17 PM
  3. Replies: 2
    Last Post: 02-04-2012, 05:27 PM
  4. Z axis depth not correct
    By jtriggs in forum Mach Mill
    Last Post: 12-27-2006, 06:52 AM
