![Quote](images/misc/quote_icon.png)
Originally Posted by
Vern Smith
..... This works fine except I cringe when the cutoff blade roars into the existing slot at warp speed.
![EEK!](images/smilies/eek.png)
Why are you retracting the parting tool in the first place?
Part down to X.56 at whatever speed and feed you are using then just put M03 S500 and follow it with the X.4 F.002. The machine will simply pause at X.56 while the spindle slows down.
You could even do it with a M00 program stop like this:
(Part to X.56)
M00 (Stop spindle and give you time to find the pencil you just dropped)![Smile](images/smilies/smile.png)
M03 S500 (Hold pencil in right hand push green button with left; or vice versa)
G01 X.4 F.002 (Catch the part)
M05 (Stop the spinning thing for safety before lifting the part away)
X3.6
etc.
Mind you, I would feel much more comfortable if you rigged up something from the tailstock instead of the pencil. You might find life on CNCzone tedious typing with only one hand.
