588,243 active members*
4,266 visitors online*
    325 Coolant Pump
    I am having a problem with my coolant pump, it starts out pumping fine & continually dies off. I pulled the pump & there's 2 rubber wasers just floating on the shaft, coolant sprays out of the top of the pump cavity & I assume that these rubber washers are there to contain that, but I don't understand how. There's a hole in the shaft, like there's supossed to be a roll pin, but it's a little too high to contain the rubber tight enough to do anything? Anybody know about these pumps?
    Also, Are they really 3phase 220volt pumps??
    www.turtleracingproducts.com
    Sep 2004
    107
    My manual only shows a pump assy, and no details about it so you may need to contact 3S.
    Yes, they are three-phase 240. I decided after hearing the horror stories of coolant growing bacteria in sumps that I wasn't going to use the sump in my machine (plus I didn't want to try and get it all the sediment loosened up and washed out), and so I bought a MicroDrop for general use, and one of those 5 gallon tanks with pumps in case I ever want to sling flood coolant all over the shop.
    cheers,
    Michael
    Mar 2012
    My pump on the TREE machine did not work when I got it and it was not easy to remove. Also some of the hoses were broken. I got a common water cooler pump. I had to redo the wiring for 110V and hook it up to a switch.
    Feb 2009
    6028
    The rubber i believe is only there to keep coolant from migrating up the shaft to the motor. You sure its turning the right direction?
    Mar 2012
    I have not used my pump a lot yet but it does pump well. It is a cheap replacement. Just beware for the wiring as the original pump is 220V and this one is 110V. I could not find the right wires to connect to make it pump only when the spindle is on so i just connected it to the wire entrance and put in an extra switch to turn the pump on and off.
  1. Adding a coolant pump to my new lathe
    By widgitmaster in forum Mini Lathe
    Last Post: 09-06-2011, 03:43 PM
  2. upgrade coolant pump
    By alabat in forum Daewoo/Doosan
    Last Post: 02-06-2007, 07:40 PM
  3. coolant pump ???
    By Loadedagain in forum Charter Oak Automation Support Forum
    Last Post: 01-03-2007, 07:54 AM
  4. Flood Coolant Pump
    By rcazwillis in forum MetalWork Discussion
    Last Post: 11-15-2005, 08:19 PM
  5. Calculation for coolant pump size?
    By FLUTE HEAD in forum Uncategorised MetalWorking Machines
    Last Post: 03-31-2005, 07:24 PM
